Discuss
kenmore washer / 2 drain holes
 in
Washer Repair
Dear Sir/Madame; My daughter recieded a Kenmore Washer, not very old. when we went to hook it up it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kenmore washer / 2 drain holes
  #1 (permalink)
Old 12-13-2007, 12:40 PM
kathysmitley kathysmitley is offline
Junior Member
kathysmitley is on a distinguished road
Default kenmore washer / 2 drain holes
Model Number: 31701   Brand: Kenmore   Age: More than 10 years
Dear Sir/Madame;
My daughter recieded a Kenmore Washer, not very old. when we went to hook it up it has 2 drain holes side by side. What hole do we use for the drain hose? We called around to the department store and no one seems to know. My husband is very confused. Can you help?
serial # c13001082
Kathy
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-13-2007, 08:12 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
i think your talking about two drain HOSES . This model is called a sud,s saver, one hose goes to the drain and the other goes to the sink basin. Just put a little water in the washer and put the 2 hoses in a bucket. watch which one the water comes out of when put in drain. You could put a[ y ] joint at the top of the single drain pipe and install the two drain hoses this won,t hurt. The washer will work.
__________________
  #3 (permalink)
Old 12-14-2007, 04:32 PM
Senior Expert
APP Volunteer
Default
I forgot to mention in the last post that what your to do is block the bottom hole with a cap or stopper and only use the top hole for your drain hose that,s if your not going to use the sud saver feature.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore washer / 2 drain holes kathysmitley Washer Repair 1 12-14-2007 12:20 PM
Calypso Washer Washer Won't Drain SamB Washer Repair 3 11-27-2007 02:41 PM
My washer will not drain lisalisajoey Washer Repair 1 10-09-2007 03:04 AM
Washer won't drain DJBaur Washer Repair 0 09-07-2007 08:56 PM
washer won't drain jmsnewton Washer Repair 5 09-04-2007 11:45 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
