Discuss
Washer motor will not run
 in
Washer Repair
The motor on our Kenmore front load washer will not start. Found open fuse on speed control board. Sears says
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer motor will not run
  #1 (permalink)
Old 12-13-2007, 10:08 AM
den1 den1 is offline
Junior Member
den1 is on a distinguished road
Default Washer motor will not run
Model Number: 41742042100   Brand: Kenmore   Age: 5 - 10 years
The motor on our Kenmore front load washer will not start. Found open fuse on speed control board. Sears says to replace board. First of all, why can't just fuse be replaced? Did some checks with volt/ohm tester and according to instructions on wiring diagram the motor resistance ohm'd out ok according to specs. Shortly before washer quit working we noticed that last few wash cycles appeared to be lasting longer than usual. Could the timer or something else been the root of the control board failure? Do not want to invest in new board and have it ruined due to some other underlying problem. How can timer be checked to make sure it is ok?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to Check Washer Motor & Capacitor mickey11 Washer Repair 2 06-15-2008 10:09 AM
Questions about motor in my Maytag washer yzhong Washer Repair 1 11-05-2007 08:24 PM
GE Washer - Motor Intermittent rmfield Washer Repair 3 11-01-2007 09:01 PM
Washer motor spins but will not agitate. jimmyr Washer Repair 1 09-19-2007 05:34 AM
Washer motor hums, but won't drain, agitate or spin redwood646 Washer Repair 2 09-11-2007 08:39 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
