Discuss
Washer has a burn smell sometimes
 in
Washer Repair
Hi. Sometimes when I turn on my washer there is a clicking sound like a switch is trying to switch
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer has a burn smell sometimes
  #1 (permalink)
Old 11-05-2011, 10:29 AM
Junior Member
MichelleK is on a distinguished road
Default Washer has a burn smell sometimes
Brand: Whirlpool   Age: 5 - 10 years
Hi. Sometimes when I turn on my washer there is a clicking sound like a switch is trying to switch on and off and the cycle won't run. I turn it off and on and wait and it will work many times but sometimes there is a burning smell and I just turn it off for an hour or so and try later. It usually works then but I know I need a new part. Do you think its the timer?
Ads By Google
  #2 (permalink)
Old 11-06-2011, 05:25 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
It is probably not the timer, but we need a model number to make any additional diagnosis.
__________________
  #3 (permalink)
Old 11-11-2011, 12:42 PM
Junior Member
Default
Quote:
OK the model # LSB6300PWO and it is a Whirlpool
  #4 (permalink)
Old 11-11-2011, 12:44 PM
Junior Member
Default
Quote:
Originally Posted by MichelleK View Post
OK the model # LSB6300PWO Whirlpool
I buzzing happens also when the washer is running the cycle.
  #5 (permalink)
Old 11-15-2011, 04:14 PM
Junior Member
Unhappy
The washer is a whirlpool model #LSB6300PWO
  #6 (permalink)
Old 11-15-2011, 07:21 PM
Senior Expert
APP Volunteer
Default
Unfortunately it can be a bunch of things.
Use the videos in this library
AppliancePartsPros's Channel - YouTube
to open it up and check out the pump, coupling and see if the transmission is hanging up in some manner. (I am assuming that it fills).
It can also be a problem with the capacitor (unusual), the motor or the timer. If you cannot find anything wrong you are going to have to just start replacing parts and see which one fixes it.
Sorry not to be more definitive, it's the nature of your problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer wont heat and has burn smell erin10 Dryer Repair 3 12-14-2010 07:19 AM
Washer stop cycle and smell as burn plastic andresm Washer Repair 3 10-23-2009 06:59 PM
new belts still burn smell goldieoldie Washer Repair 1 03-09-2009 04:19 PM
Whirlpool agitates, won't spin burn smell SBMiller Washer Repair 1 12-18-2008 04:31 AM
Stacked Washer/dryer Wont Spin/burn Smell rustknee Washer Repair 2 03-10-2008 05:23 PM
