Washer will not start. Display is blank. I think it is either part 6 or 13 in the parts diagram. Any suggestions on trouble-shooting. Thanks. Ron
Generally that problem is the mian control unit, but you will have to replace it to be certain. Make sure you have current coming into the unit.
Thanks for the response. I assume you are talking about part 6 in the diagram. Thanks. Ron
Yes, if you buy from this site and the part does not fix the problem you can return it, see the returns policy for details and conditions.
Good luck, hope that does it.
Part 6 (main control unit) did not work. Any suggestions? Thanks. Ron
Try replacing the part number 13, and if that fixes it return the other part for a refund.
Good luck.
