| » Washing Machine Leak |
Model Number: PALW880QAW1 Brand: Amana Age: 5 - 10 years
I have an Amana MFG number PALW880QAW1, Washer - Top Loading with a leak which seems to be coming from between the outer tub & the lower tub. I noticed that after removing the agitator that the center hub is very corroded. Any thoughts on what may be the problem? I so what parts do you suggest that I order?
I would pull off the front panel and verify bad tub seaL and bearing by looking at the tub seal area. If so, you will need a special gear puller to pull the old bearings. I would do a search in google to find a cheaper repair proceedure. Some techs say avoid a repair, not worth the effort, I tend to agree, this is not an easy job!
__________________
| Display Modes | |
| Washing Machine Stops When Washing | farmallnancy | Washer Repair | 1 | 12-01-2009 05:12 PM |
| Washing Maching Shake and Leak | Porter_Wagoner | Washer Repair | 3 | 06-18-2009 10:40 PM |
| washing machine tub seal replacement due to leak | rkbean1 | Washer Repair | 3 | 08-07-2008 04:35 AM |
| washing machine takes hours to finish washing a load | kelly Monday | Washer Repair | 2 | 09-26-2007 02:42 AM |
