Discuss
Washer Not Drain Propelly
 in
Washer Repair
Hi, My name is Raymond from South Africa. I have a problem with my washing machine, it does not drain
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Not Drain Propelly
  #1 (permalink)
Old 11-04-2011, 07:43 PM
Junior Member
mvangeli raymond Khumalo is on a distinguished road
Default Washer Not Drain Propelly
Model Number: DEFY AUTOMAID 600 DAW 317   Brand: -other-   Age: 1 - 5 years
Hi, My name is Raymond from South Africa. I have a problem with my washing machine, it does not drain well in such way that after drain&spin leaves the clothes still wet. What amazed me is that when I select drain and spin it does that very well. I checked pump - seems to be ok, however when I opened the drain pipe from the drum to the inlet of the pump I found some coins some ,strings from the clothes and I cleared all that but the problem is still there. I don't know what else to do I have been trying to look for the filter which I could not find. Also what is the purpose of the small ball found at the inlet of the drain from the drum to the pump ? Can you please give me some advice with this regards and also help me to locate the filter.
Thank you
From Raymond
Ads By Google
Related Models
Frigidaire DEGCIFL3 Frg(v3) / 27 " Gas Dryer
Amana DEI-512 Range - S/c S/i Ddraft Gas
Amana DEI-522 Range - S/c S/i Ddraft Gas
Amana DEI-522C Range - S/c S/i Ddraft Gas
Frigidaire DEIDH1 Frg(v8) / Gas and Electric Dryers
Frigidaire DEIDL1 Frg(v9) / Gas and Electric Dryers
Frigidaire DEIDW1 Frg(v7) / Gas and Electric Dryers
Frigidaire DEIFL0 Frg(v2) / Electric Dryer
Frigidaire DEIFW0 Frg(v1) / Electric Dryer
Frigidaire DEILL1 Frg(v2) / 27 " Electric Dryer
Frigidaire DEILL2 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILL3 Frg(v2) / 27 " Electric Dryer
Frigidaire DEILL4 Frg(v2) / 27 " Electric Dryer
Frigidaire DEILL5 Wwh(v2) / 27 " Electric Dryer
Frigidaire DEILW1 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILW2 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILW3 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILW4 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILW5 Frg(v1) / 27 " Electric Dryer
Frigidaire DEISFL0 Frg(v4) / Electric Dryer
Frigidaire DEISFL1 Frg(v4) / 27 " Electric Dryer
Frigidaire DEISFL2 Frg(v2) / 27 " Electric Dryer
Frigidaire DEISFL3 Frg(v4) / 27 " Electric Dryer
Frigidaire DEISFL4 Frg(v4) / 27 " Electric Dryer
Frigidaire DEISFL5 Frg(v4) / 27 " Electric Dryer
Frigidaire DEISFW0 Frg(v3) / Electric Dryer
Frigidaire DEISFW1 Frg(v3) / 27 " Electric Dryer
Frigidaire DEISFW2 Frg(v2) / 27 " Electric Dryer
Frigidaire DEISFW3 Frg(v3) / 27 " Electric Dryer
Frigidaire DEISFW4 Frg(v3) / 27 " Electric Dryer
Frigidaire DEISFW5 Frg(v3) / 27 " Electric Dryer
Norge DEJ20800 Dryer - Ele
Norge DEJ20824 Dryer - Ele
Norge DEJ20825 Dryer - Ele
Norge DEJ208A Dryer - Ele
Norge DEJ208H Dryer - Ele
Norge DEJ208W Dryer - Ele
Norge DEJ25400 Dryer - Ele
Norge DEJ25424 Dryer - Ele
Norge DEJ25425 Dryer - Ele
Norge DEJ25426 Dryer - Ele
Norge DEJ25427 Dryer - Ele
Norge DEJ254A Dryer - Ele
Norge DEJ254H Dryer - Ele
Norge DEJ254W Dryer - Ele
Norge DEJ26400 Dryer - Ele
Norge DEJ26424 Dryer - Ele
Norge DEJ26425 Dryer - Ele
Norge DEJ26426 Dryer - Ele
Norge DEJ26427 Dryer - Ele
Norge DEJ264A Dryer - Ele
Norge DEJ264H Dryer - Ele
Norge DEJ264W Dryer - Ele
Norge DEK201AC Dryer - Ele
Norge DEK201WC Dryer - Ele
Norge DEK204AC Dryer - Ele
Norge DEK204HC Dryer - Ele
Norge DEK204WC Dryer - Ele
Menu Master DEL10D  Commercial Microwaves
Menu Master DEL10E  Commercial Microwaves
Norge DEL202A Dryer - Ele
Norge DEL202C Dryer - Ele
Norge DEL202H Dryer - Ele
Norge DEL202W Dryer - Ele
Norge DEL202WC Dryer - Ele
Norge DEL203 Dryer - Ele
Norge DEL203A Dryer - Ele
Norge DEL203AC Dryer - Ele
Norge DEL203H Dryer - Ele
Norge DEL203HC Dryer - Ele
Norge DEL203W Dryer - Ele
Norge DEL203WC Dryer - Ele
Norge DEL204A Dryer - Ele
Norge DEL204H Dryer - Ele
Norge DEL204W Dryer - Ele
Norge DEL253A Dryer - Ele
Norge DEL253H Dryer - Ele
Norge DEL253W Dryer - Ele
Norge DEL263A Dryer - Ele
Norge DEL263H Dryer - Ele
Norge DEL263W Dryer - Ele
Norge DEM202A Dryer - Ele
Norge DEM202AC Dryer - Ele
Norge DEM202H Dryer - Ele
Norge DEM202HC Dryer - Ele
Norge DEM202W Dryer - Ele
Norge DEM202WC Dryer - Ele
Norge DEM204 Dryer - Ele
Norge DEM204 REV A Dryer - Ele
Norge DEM204 REV B Dryer - Ele
Norge DEM204 REV C Dryer - Ele
Norge DEM204A Dryer - Ele
Norge DEM204AC Dryer - Ele
Norge DEM204H Dryer - Ele
Norge DEM204HC Dryer - Ele
Norge DEM204W Dryer - Ele
Norge DEM204WC Dryer - Ele
Norge DEM205A Dryer - Ele
Norge DEM205AC Dryer - Ele
Norge DEM205H Dryer - Ele
Norge DEM205W Dryer - Ele
Norge DEM205WC Dryer - Ele
Norge DEN202A Dryer - Ele
Norge DEN202AC Dryer - Ele
Norge DEN202W Dryer - Ele
Norge DEN202WC Dryer - Ele
Norge DEN203A Dryer - Ele
Norge DEN203AC Dryer - Ele
Norge DEN203W Dryer - Ele
Norge DEN203WC Dryer - Ele
Norge DEN204A Dryer - Ele
Norge DEN204GV Dryer - Ele
Norge DEN204KA Dryer - Ele
Norge DEN204KV Dryer - Ele
Norge DEN204KW Dryer - Ele
Norge DEN204V Dryer - Ele
Norge DEN204VC Dryer - Ele
Norge DEN204W Dryer - Ele
Norge DEP222VC Dryer - Ele
Norge DEP223M Dryer - Ele
Last edited by mvangeli raymond Khumalo : 11-04-2011 at 07:47 PM. Reason: My washing machine is a front loader
  #2 (permalink)
Old 11-05-2011, 06:41 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Raymond
We here in the U.S. cannot identify your model. It may be a variation of a U. S. model, so if you can tell us who made it and give a good description, or post a couple of pictures we may be able to identify it and help.
Normally your problem would be some type of obstruction, but the fact that it drains and spins sometimes is confusing to us, sounds like to you also.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer will only drain if put on "Drain+Spin" cycle. Arieleno Washer Repair 7 11-02-2011 07:03 PM
My Hotpoint washer won't drain or spin, but it will if I drain the hose by gravity? ks_becker Washer Repair 0 08-10-2010 10:25 AM
Washer won't drain lk2ski Washer Repair 0 04-14-2008 08:33 AM
Calypso Washer Washer Won't Drain SamB Washer Repair 3 11-27-2007 01:41 PM
My washer will not drain lisalisajoey Washer Repair 1 10-09-2007 02:04 AM
