The male half of the door latch broke, which was easy to replace. However after replacing the door latch the LED for the Wash Cycle Selector continues to blink and the washer will not start its wash cycle. All the other LED apear to be working fine. Any suggestions as to the problem?:confused:
Groups: Joined: 12/1/2008(UTC) Posts: 0
Originally Posted by: mjcruz65 The male half of the door latch broke, which was easy to replace. However after replacing the door latch the LED for the Wash Cycle Selector continues to blink and the washer will not start its wash cycle. All the other LED apear to be working fine. Any suggestions as to the problem?:confused: Hi MJcruz65. The door latch circuit is still not working correctly. Use door switch part # Part number: AP3837611
. Thank You.
