Discuss
frigidaire washer will not spin
 in
Washer Repair
not sure if age is correct, but last time it ran the spin cycle dod not work. motor and capacitor
Appliance Repair Forum > Appliance Repair Help > Washer Repair » frigidaire washer will not spin
  #1 (permalink)
Old 12-12-2007, 07:26 PM
herbul73 herbul73 is offline
Junior Member
herbul73 is on a distinguished road
Default frigidaire washer will not spin
Model Number: FWS445RFS0   Brand: Frigidaire   Age: 1 - 5 years
not sure if age is correct, but last time it ran the spin cycle dod not work. motor and capacitor are new. the motor humms when manually set to spin.any help appreciated jeff
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-14-2007, 12:25 PM
Junior Member
Default update
both agitation and spin cycles don't work.if i spin the motor over by hand it starts but otherwise just humms.please help thanks jeff
  #3 (permalink)
Old 12-14-2007, 06:02 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
When did you replace the motor? Sounds like the motor start winding is not good.
Remove the belt and check if the motor will start by itself.
__________________
Professional appliance repair in Los Angeles, California.
  #4 (permalink)
Old 12-14-2007, 09:10 PM
Junior Member
Default
gene thanks for the reply. i just ordered the motor and capacitor just this week from this site with no results. i tried it with the belt off and the same. is there anything else i can test on the motor or elsewhere. thanks jeff
  #5 (permalink)
Old 12-14-2007, 10:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If there is the new motor then check the wire connection to the motor and wires from the timer to the motor.
If there is nothing wrong then the timer has to be replaced.
- The part number for the timer is AP2106876
__________________
  #6 (permalink)
Old 12-15-2007, 01:59 PM
Junior Member
Default
update - i took the timer apart and cleaned the contacts up and looking good and put it EXACTLY back together and the same. here is what i have figured out so far. on both spin and agitate the wires carrying 120v are purple ,grey orange and red. not hot are black w/white stripe and black w/red stripe. does anyone know if this is correct?
  #7 (permalink)
Old 12-16-2007, 12:36 PM
Junior Member
Default
well this one i had to figure out myself. the wire coming out of the timer harness had no conitunity at the motor (black w/red stripe) works like a charm now. live and learn.thanks for your replys gene. jeff
  #8 (permalink)
Old 12-16-2007, 04:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
Merry Christmas and Happy New year!
__________________
  #9 (permalink)
Old 12-18-2007, 03:56 PM
JEFFREYROBERT JEFFREYROBERT is offline
Junior Member
JEFFREYROBERT is on a distinguished road
Default
Take The Belt Off The Motor And See If The Motor Runs Under No Load
  #10 (permalink)
Old 01-05-2008, 02:12 PM
lnahudson lnahudson is offline
Junior Member
lnahudson is on a distinguished road
Default
I was following this thread and did not take the timer apart but pulled the belt and now the motor will spin. What does that mean? All other symptons were the same.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire front loader will not spin lone-rider Washer Repair 5 12-20-2007 09:31 AM
Frigidaire Front Load Washer Won't Spin bbemis Washer Repair 2 11-28-2007 08:46 AM
Frigidaire won't spin or drain Buckythecat Washer Repair 0 11-06-2007 11:30 AM
spin cycle on frigidaire front load Mikki Washer Repair 2 10-08-2007 05:15 PM
Frigidaire washer beanjamin55@yahoo.com Washer Repair 0 10-06-2007 02:47 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
