Discuss
Amana washer balance/leak
 in
Washer Repair
When I am in an agitation part of the cycle, the drum is very "wobbly" this starts a wave traveling
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Amana washer balance/leak
  #1 (permalink)
Old 11-03-2011, 12:39 PM
Junior Member
jrawski is on a distinguished road
Default Amana washer balance/leak
Model Number: LW3903L   Brand: Amana   Age: More than 10 years
When I am in an agitation part of the cycle, the drum is very "wobbly" this starts a wave traveling around the drum and it eventually builds up high enough to splash up through the drain holes in the plastic splash shield on the top of the drum. When this starts it will fill up the cavities on the top of the slash shield and water will be flung off the top of the drum, filling the bottom of the washer and eventually the floor.
Is this just old/weak springs or is there something that helps stabalize the drum in the base mounting?
How do I stabalize the drum to stop the leaking/splashing out the top?
Related Models
Amana LW3903L WASHER-TOP LOADING
Amana LW3903W WASHER-TOP LOADING
Amana LW4202L WASHER-TOP LOADING
Amana LW4202W WASHER-TOP LOADING
Amana LW4203L2 WASHER-TOP LOADING
Amana LW4203W2 WASHER-TOP LOADING
Amana LW4302L WASHER-TOP LOADING
Amana LW4302W WASHER-TOP LOADING
Amana LW4303L WASHER-TOP LOADING
Amana LW4303W WASHER-TOP LOADING
Amana LW4603L WASHER-TOP LOADING
Amana LW4603W WASHER-TOP LOADING
 LW5200ER Air Conditioner
Amana LW6001W2 WASHER-TOP LOADING
Amana LW6101WB WASHER-TOP LOADING
Amana LW6111LB WASHER-TOP LOADING
Amana LW6111WB WASHER-TOP LOADING
Amana LW6123LM WASHER-TOP LOADING
Amana LW6123WM WASHER-TOP LOADING
Amana LW6143LM WASHER-TOP LOADING
Amana LW6143WM WASHER-TOP LOADING
Amana LW6153LB WASHER-TOP LOADING
Amana LW6153LM WASHER-TOP LOADING
Amana LW6153WB WASHER-TOP LOADING
Amana LW6153WM WASHER-TOP LOADING
Amana LW6163LM WASHER-TOP LOADING
Amana LW6163WM WASHER-TOP LOADING
Amana LW6501W2 WASHER-TOP LOADING
Amana LW6501W2B WASHER-TOP LOADING
Amana LW6601W2 WASHER-TOP LOADING
Amana LW6661W2 WASHER-TOP LOADING
Amana LW7503L2 WASHER-TOP LOADING
Amana LW7503W2 WASHER-TOP LOADING
Amana LW7563W2 WASHER-TOP LOADING
 LW8000ER Air Conditioner
Amana LW8201L2 WASHER-TOP LOADING
Amana LW8201W2 WASHER-TOP LOADING
Amana LW8203L2 WASHER-TOP LOADING
Amana LW8203W WASHER-TOP LOADING
Amana LW8203W2 WASHER-TOP LOADING
Amana LW8203W2B WASHER-TOP LOADING
Amana LW8252L2 WASHER-TOP LOADING
Amana LW8252W2 WASHER-TOP LOADING
Amana LW8253W WASHER-TOP LOADING
Amana LW8263W2 WASHER-TOP LOADING
Amana LW8303L2 WASHER-TOP LOADING
Amana LW8303W2 WASHER-TOP LOADING
Amana LW8312L2 WASHER-TOP LOADING
Amana LW8312W2 WASHER-TOP LOADING
Amana LW8363L2 WASHER-TOP LOADING
Amana LW8363W2 WASHER-TOP LOADING
Amana LW8403W WASHER-TOP LOADING
Amana LW8413L2 WASHER-TOP LOADING
Amana LW8413W2 WASHER-TOP LOADING
Amana LW8413W2B WASHER-TOP LOADING
Amana LW8463L2 WASHER-TOP LOADING
Amana LW8463W2 WASHER-TOP LOADING
Amana LW9003 WASHER-TOP LOADING
Amana LW9103 WASHER-TOP LOADING
Amana LW9103W WASHER-TOP LOADING
Amana LW9203L2 WASHER-TOP LOADING
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana washer water leak beejosh Washer Repair 1 07-04-2011 12:44 PM
Amana water dispenser leak repairandy Refrigerator & Freezer Repair 0 12-01-2010 07:33 PM
amana washer leak dledmons Washer Repair 1 11-14-2010 06:13 AM
Amana Ice Maker Leak leakie2 Refrigerator & Freezer Repair 0 02-02-2010 06:25 AM
amana leak then smoke pavel goldburn Washer Repair 1 08-09-2009 07:39 AM
