Discuss
trouble getting the belt on correctly
 in
Washer Repair
I replaced the washer pump but now I don't think the tensioner is in the right place as the washer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » trouble getting the belt on correctly
  #1 (permalink)
Old 11-03-2011, 11:33 AM
Junior Member
garygordon is on a distinguished road
Default trouble getting the belt on correctly
Model Number: awm371w2   Brand: Amana   Age: 5 - 10 years
I replaced the washer pump but now I don't think the tensioner is in the right place as the washer does not spin out completely(still very damp clothes) and the pump does not want to shut off after the spin cycle is over.
Related Models
Amana AWM371W2 WASHER-TOP LOADING
Amana AWM372W WASHER-TOP LOADING
Amana AWM372W2 WASHER-TOP LOADING
Amana AWM373W WASHER-TOP LOADING
Amana AWM373W2 WASHER-TOP LOADING
Amana AWM392L WASHER-TOP LOADING
Amana AWM392L2 WASHER-TOP LOADING
Amana AWM392W WASHER-TOP LOADING
Amana AWM392W2 WASHER-TOP LOADING
Amana AWM393L WASHER-TOP LOADING
Amana AWM393L2 WASHER-TOP LOADING
Amana AWM393W WASHER-TOP LOADING
Amana AWM393W2 WASHER-TOP LOADING
Amana AWM432 WASHER-TOP LOADING
Amana AWM452 WASHER-TOP LOADING
Amana AWM472W WASHER-TOP LOADING
Amana AWM472W2 WASHER-TOP LOADING
Amana AWM473W WASHER-TOP LOADING
Amana AWM473W2 WASHER-TOP LOADING
Amana AWM492 WASHER-TOP LOADING
Amana AWM493 WASHER-TOP LOADING
Amana AWM531 WASHER-TOP LOADING
Amana AWM551 WASHER-TOP LOADING
Amana AWM572 WASHER-TOP LOADING
Amana AWM573W WASHER-TOP LOADING
Amana AWM573W2 WASHER-TOP LOADING
Amana AWM592 WASHER-TOP LOADING
Amana AWM593L WASHER-TOP LOADING
Amana AWM593L2 WASHER-TOP LOADING
Amana AWM593W WASHER-TOP LOADING
Amana AWM593W2 WASHER-TOP LOADING
Amana AWM631 WASHER-TOP LOADING
Amana AWM651 WASHER-TOP LOADING
Amana AWM692 WASHER-TOP LOADING
Amana AWM693 WASHER-TOP LOADING
Frigidaire AWP110S2W Kel(v3) / 24 " Washer
Frigidaire AWP220S2W Kel(v4) / 24 " Washer
Frigidaire AWP330A0D Kel(v4) / 24 " Washer
Frigidaire AWP330A0T Kel(v5) / 24 " Washer
Frigidaire AWP330A0W Kel(v6) / 24 " Washer
Frigidaire AWP330A1D Kel(v4) / 24 " Washer
Frigidaire AWP330A1T Kel(v5) / 24 " Washer
Frigidaire AWP330A1W Kel(v6) / 24 " Washer
Frigidaire AWP330F1D Kel(v2) / 24 " Washer
Frigidaire AWP330F1W Kel(v1) / 24 " Washer
Frigidaire AWP330F2D Kel(v2) / 24 " Washer
Frigidaire AWP330F2W Kel(v1) / 24 " Washer
Frigidaire AWP330G1D Kel(v2) / 24 " Washer
Frigidaire AWP330G1W Kel(v1) / 24 " Washer
Frigidaire AWP330H1L Kel(v2) / 24 " Washer
Frigidaire AWP330H1W Kel(v1) / 24 " Washer
Frigidaire AWP330H2D Kel(v2) / 24 " Washer
Frigidaire AWP330H2W Kel(v1) / 24 " Washer
Frigidaire AWP330H3D Kel(v2) / 24 " Washer
Frigidaire AWP330H3W Kel(v1) / 24 " Washer
Frigidaire AWS100C1D Kel(v1) / Tumble Action Washer
Frigidaire AWS100C1W Kel(v2) / Tumble Action Washer
Whirlpool AX5133VG0
Whirlpool AX5133VG1
Whirlpool AX5133VL0
Whirlpool AX5133VL1
Whirlpool AX5133VW0
Whirlpool AX5133VW1
Whirlpool AX6245VG0
Whirlpool AX6245VG1
Whirlpool AX6245VL0
Whirlpool AX6245VL1
Whirlpool AX6245VW0
Whirlpool AX6245VW1
Whirlpool AXC-145-44 AIR CONDITIONER
General Electric AXN18W1G1 Room air conditioner
General Electric AXN18W1G2 Room air conditioner
General Electric AXN18W2G1 Room air conditioner
General Electric AXN19W2G1 Room air conditioner
General Electric AXN19W3G1 Room air conditioner
General Electric AXN21W3X1 Room air conditioner
General Electric AXN24W1X1 Room air conditioner
General Electric AXN25W3C1 Room air conditioner
General Electric AXN30W3X1 Room air conditioner
General Electric AXQ05LPQ1 ROOM AIR CONDITIONER
General Electric AXQ06LPQ1 ROOM AIR CONDITIONER
Admiral AYE1000AYW DRYER- ELE
Admiral AYE1200AKW DRYER- ELE
Admiral AYE2200AGW DRYER- ELE
Admiral AYE2250AYA DRYER- ELE
Admiral AYE2250AYW DRYER- ELE
Admiral AYG1000AWW DRYER- GAS
Admiral AYG1200AWA DRYER- GAS
Admiral AYG1200AWW DRYER- GAS
Admiral AYG2200AGW DRYER- GAS
General Electric AZ21E06D2CV1 Room air conditioner
General Electric AZ21E06D2CV3 Room air conditioner
General Electric AZ21E06D3CV1 Room air conditioner
General Electric AZ21E06D3CV3 Room air conditioner
General Electric AZ21E06D3CV6 Room air conditioner
General Electric AZ21E06DACV1 Zoneline
General Electric AZ21E06E2CV1 Room air conditioner
General Electric AZ21E06E2CV3 Room air conditioner
General Electric AZ21E06E3CV1 Room air conditioner
General Electric AZ21E06E3CV3 Room air conditioner
General Electric AZ21E06E4CV1 Room air conditioner
General Electric AZ21E06E4CV3 Room air conditioner
General Electric AZ21E06E4CV6 Zoneline
General Electric AZ21E06EACV1 Zoneline
General Electric AZ21E09CDCV1 Zoneline
General Electric AZ21E09D2CV1 Room air conditioner
General Electric AZ21E09D2CV3 Room air conditioner
General Electric AZ21E09D3CV1 Room air conditioner
  #2 (permalink)
Old 11-03-2011, 12:49 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Gary,
You'll need to recheck the belt installation and idler assembly. Here's some help:
Reassembly of Pump and Belt
NOTE:
Install pump and belt together. Drive belt MUST be replaced with belt No. 40053602 for one and two speed models; or 40053601 for some two speed models and three speed models (special clutch-type belt) for proper washer operation. Refer to Parts Manual for proper belt part number.
1. Remove any corrosion or foreign material from motor shaft.
2. Apply a thin film of No. 03637P lubricant to the end and sides of motor shaft.
3. Align belt on motor pulley and tension pulley.
4. Align pump impeller hub with motor shaft. Verify belt encircles rear pump leg. Slide pump onto motor shaft until legs touch the embosses on the motor housing before securing.
NOTE:
Tighten screws to 35 inch-pounds maximum. DO NOT overtighten screws!
5. Install motor and pump assembly into washer,
Idler Lever and Pulley:
NOTE:
Lay motor on its side. Observe belt configuration around rear pump leg. Belt MUST encircle rear pump leg when reassembling.
2. Remove nut, washer, and bolt securing idler lever and pulley to motor mounting bracket.
3. Apply a light film of No. 03637P Lubricant to area of idler lever that makes contact with motor mounting bracket.
NOTE: DO NOT OVER LUBRICATE!
Excess lubricant can be thrown into pivot dome area during normal washer operation. Any lubricant on the pivot dome, base or friction ring will affect washer operation.
4. Reverse procedure to reassemble.
I'm sure you'll have it fixxed and running in no time.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
trouble replacing belt GE Electric Dryer lshelly40 Dryer Repair 1 02-07-2011 04:12 AM
Trouble with belt replacement jsks99 Washer Repair 1 12-24-2010 07:09 AM
motor turns easily when I pull belt, but fault code manual says to remove belt first kenrepair Washer Repair 0 10-21-2010 05:58 AM
Amana top load belt broke, new belt smokes mikeyfz Washer Repair 1 08-28-2010 04:46 PM
How do I put belt on correctly too much slack Stacie Dryer Repair 0 11-06-2007 12:15 PM
