Discuss
Whirlpool washer won't spin on rinse cycle or high spin
 in
Washer Repair
I stuffed some towels in there and now it won't work right. What it will do is go through the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer won't spin on rinse cycle or high spin
  #1 (permalink)
Old 05-16-2009, 03:04 PM
Junior Member
bry21317 is on a distinguished road
Default Whirlpool washer won't spin on rinse cycle or high spin
Model Number: LSQ8243HQ   Brand: Whirlpool   Age: 5 - 10 years
What it will do is go through the entire cycle untiil it gets to the Rinse, then the motor stops spinning and makes a buzzing noise, as if it can't spin the drum.
I was able to pull all the towels out of the washer, then turn it on and hold the trigger switch down on the lid, to make it turn on. It then would spin at High speed. I then dropped one towel in at a time to get the water out of them, and kept adding up to about 7, it ran fine wih them being hand dropped in it. Once the water was out of the towels or the spun for a few minutes, they were pretty dry. I then removed them and put them in the dryer, but it will not work when there is a full load of water/towels in the washer.
So it goes through the Agitation no problem, where I get a problem is right before rinse. What it does is turn the pump on, then tries to speed up to remove the water from the tank. Well it can not speed up, I hear a clicking noise and the motor is starting to overheat when this happens. Anything touching the plastic base at the very bottom, stops it and it wiill then make this clicking noise.
I have tried gettiing it spinning then dropping the towels back in there and that will work one by one, but if its not spinning fast enough and slows down then it will stop the motor again, so I am guessing I have a bad motor and its triggering the relay, by pulling to much power to spin it.
Anyone got any ideas?
Thanks for all the help.
Bryan
Ads By Google
Related Models
Whirlpool LSQ8243HQ0
Whirlpool LSQ8243HZ0
Whirlpool LSQ8500JQ0
Whirlpool LSQ8500JQ1
Whirlpool LSQ8500JQ2
Whirlpool LSQ8500JT0
Whirlpool LSQ8500JT1
Whirlpool LSQ8500JT2
Whirlpool LSQ8500LQ0 Automatic Washer
Whirlpool LSQ8510LQ0 Automatic Washer
Whirlpool LSQ8511KQ0
Whirlpool LSQ8511KT0
Whirlpool LSQ8512KQ0
Whirlpool LSQ8512KT0
Whirlpool LSQ8520JQ0
Whirlpool LSQ8520JQ1
Whirlpool LSQ8543JQ0
Whirlpool LSQ8543JQ1
Whirlpool LSQ8543JT0
Whirlpool LSQ8543JT1
Whirlpool LSQ8543JZ0
Whirlpool LSQ8543JZ1
Whirlpool LSQ9010KQ0
Whirlpool LSQ9010KT0
Whirlpool LSQ9010LG0
Whirlpool LSQ9010LG1 Automatic Washer
Whirlpool LSQ9010LG2 Automatic Washer
Whirlpool LSQ9010LG3 Automatic Washer
Whirlpool LSQ9010LQ0
Whirlpool LSQ9010LQ1 Automatic Washer
Whirlpool LSQ9010LQ2 Automatic Washer
Whirlpool LSQ9010LW0
Whirlpool LSQ9010LW1 Automatic Washer
Whirlpool LSQ9010LW2 Automatic Washer
Whirlpool LSQ9010LW3 Automatic Washer
Whirlpool LSQ9010PG0 Automatic Washer
Whirlpool LSQ9010PG1 Automatic Washer
Whirlpool LSQ9010PG2 Automatic Washer
Whirlpool LSQ9010PG3 Automatic Washer
Whirlpool LSQ9010PG5 Automatic Washer
Whirlpool LSQ9010PG6 Automatic Washer
Whirlpool LSQ9010PW0 Automatic Washer
Whirlpool LSQ9010PW1 Automatic Washer
Whirlpool LSQ9010PW2 Automatic Washer
Whirlpool LSQ9010PW3 Automatic Washer
Whirlpool LSQ9010PW5 Automatic Washer
Whirlpool LSQ9010PW6 Automatic Washer
Whirlpool LSQ9030PQ0 Automatic Washer
Whirlpool LSQ9030PQ1 Automatic Washer
Whirlpool LSQ9030PQ2 Automatic Washer
Whirlpool LSQ9030PQ4 Automatic Washer
Whirlpool LSQ9030PQ5 Automatic Washer
Whirlpool LSQ9110KQ0
Whirlpool LSQ9110KQ1
Whirlpool LSQ9110LG0
Whirlpool LSQ9110LG1 Automatic Washer
Whirlpool LSQ9110LW0
Whirlpool LSQ9110LW1 Automatic Washer
Whirlpool LSQ9110PW0 Automatic Washer
Whirlpool LSQ9110PW1 Automatic Washer
Whirlpool LSQ9110PW2 Automatic Washer
Whirlpool LSQ9110PW3 Automatic Washer
Whirlpool LSQ9110PW4 Automatic Washer
Whirlpool LSQ9200KQ0
Whirlpool LSQ9200KT0
Whirlpool LSQ9200LQ0
Whirlpool LSQ9200LQ1 Automatic Washer
Whirlpool LSQ9200LQ2 Automatic Washer
Whirlpool LSQ9200LQ3 Automatic Washer
Whirlpool LSQ9200LT0
Whirlpool LSQ9200LT1 Automatic Washer
Whirlpool LSQ9200LT2 Automatic Washer
Whirlpool LSQ9200LT3 Automatic Washer
Whirlpool LSQ9200PQ0 Automatic Washer
Whirlpool LSQ9200PQ1 Automatic Washer
Whirlpool LSQ9200PQ3 Automatic Washer
Whirlpool LSQ9200PQ4 Automatic Washer
Whirlpool LSQ9200PT0 Automatic Washer
Whirlpool LSQ9200PT1 Automatic Washer
Whirlpool LSQ9200PT3 Automatic Washer
Whirlpool LSQ9200PT4 Automatic Washer
Whirlpool LSQ9210HQ0
Whirlpool LSQ9210HZ0
Whirlpool LSQ9211KQ0
Whirlpool LSQ9211KQ1
Whirlpool LSQ9211KT0
Whirlpool LSQ9211KT1
Whirlpool LSQ9244EQ0
Whirlpool LSQ9244EZ0
Whirlpool LSQ9264HQ0
Whirlpool LSQ9264HZ0
Whirlpool LSQ9500LQ0
Whirlpool LSQ9500LT0
Whirlpool LSQ9510JQ0
Whirlpool LSQ9510JQ1
Whirlpool LSQ9510LQ0
Whirlpool LSQ9510LT0
Whirlpool LSQ9520LQ0
Whirlpool LSQ9520LT0
Whirlpool LSQ9544KQ0
Whirlpool LSQ9544KT0
Whirlpool LSQ9549LG0
Whirlpool LSQ9549LG1 Automatic Washer
Whirlpool LSQ9549LG2 Automatic Washer
Whirlpool LSQ9549LG3 Automatic Washer
Whirlpool LSQ9549LQ0
Whirlpool LSQ9549LQ1 Automatic Washer
Whirlpool LSQ9549LQ2 Automatic Washer
Whirlpool LSQ9549LQ3 Automatic Washer
Whirlpool LSQ9549LW0
Whirlpool LSQ9549LW1 Automatic Washer
Whirlpool LSQ9549LW2 Automatic Washer
Whirlpool LSQ9549LW3 Automatic Washer
Whirlpool LSQ9549PG0 Automatic Washer
Whirlpool LSQ9549PG1 Automatic Washer
Whirlpool LSQ9549PG2 Automatic Washer
Whirlpool LSQ9549PG3 Automatic Washer
Whirlpool LSQ9549PG5 Automatic Washer
Whirlpool LSQ9549PG6 Automatic Washer
Whirlpool LSQ9549PW0 Automatic Washer
  #2 (permalink)
Old 05-18-2009, 07:08 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I think we have good news for you.
You should not have a motor problem, since it will agitate. This is good because a motor is expensive.
You probably need to replace the clutch. This is good because it is a relatively easy repair and it is an inexpensive part.
Here is a good site which will take you through the process.
Clutch Replacement on Whirlpool and Kenmore Washers
Good luck and let us know how you do.
__________________
  #3 (permalink)
Old 07-18-2009, 02:15 AM
Junior Member
another_no_clue is on a distinguished road
Default
Whirlpool Model LSB6400KQ1, Type 111 The water fills the tub adequately and the agitator moves normally and everything appears to work until it hits the rinse cycle when the water is being pumped out, but the tub is not moving. The motor has the usual sound during rinsing is just that the tub is not spinning. The tub feels engaged (is not moving easily) when I try to move it by hand which it also seems to be the way it has been when it used to operate. Today I replaced the motor coupler (with the new style that has metal inserts) after a 30 seconds read thru the posts, not paying attention that it was for a different problem
Sounds like another bad clutch also? (same as bry21317)
Thanks!
  #4 (permalink)
Old 07-18-2009, 07:10 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
For both of you, read my article in the "sticky" above "replacing direct drive washer brake shoes", just might be your problem.
For Bry, shine a light in the tub, you probably have something stuck in the tub; either that or sticking brake shoes, You are lucky your motor didn't burn up.
__________________
  #5 (permalink)
Old 08-19-2009, 06:32 PM
Junior Member
boshman is on a distinguished road
Default
check your gear case too. check for leaking oil. if it is leaking oil you need to replace the transmission and the clutch. do you smell like a burning rubber smell or smoke?
  #6 (permalink)
Old 04-10-2011, 08:47 PM
Junior Member
miswmn is on a distinguished road
Unhappy Rinse cycle not spinning and getting all the soap out.
My washer works normally until the rinse cycle. The water drains out and starts to refill the tub. It sounds like it is spinning, but without the turning. The soap does not always rinse out either. I have to restart the rinse cycle to get the rest of the soap out.
Sometimes I think I might smell a hint of a burnt rubber smell. Do you think it is the clutch, transmission or brake shoes? Thanks!
Quote:
  #7 (permalink)
Old 04-11-2011, 01:33 AM
Senior Expert
APP Volunteer
Default
Remove the outer cabinet, short the lid switch, and in spin, verify the clutch housing moves without the spin basket turning. If so, you have a worn out clutch and bad brake shoes.
__________________
  #8 (permalink)
Old 04-18-2011, 10:03 AM
Junior Member
dougm25 is on a distinguished road
Default
I have a Whirlpool Model lsq9560pw3. How would you know if the clutch is bad versus the brakes? Thanks!! DOUG
  #9 (permalink)
Old 04-18-2011, 02:00 PM
Junior Member
Default
Thanks for the help on these changes... I wound up changing the motor coupling and clutch assembly (with brake shoes). When I tested it, the lid switch fell apart in my hand, so I changed that out as well. It was hard to turn the inside tub, but I pushed it a couple of times to see if something was stuck between the tubs. Apparently, the object came out. The washer is just as good as it was when we first bought it. Thank you!
P.S. The tutorials you give on YouTube are excellent!
  #10 (permalink)
Old 05-24-2011, 08:56 AM
Junior Member
sears is on a distinguished road
Default Washer 11024832200
Hello , and thanks in advance for the help. The lid pin activator is broken, I can't drain the water and the washer spin cycle is broken.
Reply
« Mike | mimartin59 »
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Does Not Rinse During Spin Cycle Ladycarr Washer Repair 4 02-12-2010 08:54 PM
Whirlpool washer loud noise (like a generator) during Rinse & Spin Cycle KM Rahman Washer Repair 1 01-05-2010 05:17 PM
GE Washer will not spin on rinse cycle mguy77 Washer Repair 2 05-08-2009 09:15 AM
Washer goes to rinse cycle then spin back to rinse, stuck in this mod Pat66 Washer Repair 1 05-08-2009 07:44 AM
Washer won't spin in rinse cycle PIETOWN Washer Repair 1 01-28-2008 01:13 PM
