Discuss
Electrolux Affinity E20 Code
 in
Washer Repair
We have an Electrolux Affinity ATF6000FSO that has begun showing an E20 error code. It will get about half way
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Electrolux Affinity E20 Code
  #1 (permalink)
Old 11-01-2011, 09:36 AM
Junior Member
ThomasH is on a distinguished road
Default Electrolux Affinity E20 Code
Model Number: ARF6000FSO   Brand: Electrolux   Age: 1 - 5 years
We have an Electrolux Affinity ATF6000FSO that has begun showing an E20 error code. It will get about half way through a cycle and the error code shows up. At the start of the cylcle, it will fill with water initially, but it never really spins during the cycle. It will pump the water out then the E20 code come on with much time remaining. I have researched on line and all indications say the E20 code is a clogged pump/hose/catch basin/filter? The water seems to pump out fine as it drains out of the hose into the home water drain. Where can I get a repair manual? I opened the back yesterday and am not sure where to begin checking hoses. There is a black bellows looking piece that has a hose coming from the tub. the black bellows is attached to the pump and then a hose coming off of it up to the exit hose on the back. Should I try and clean out any of these parts? HELP!
Related Models
Amana ARG3600L RANGE- S/C S/I DDRAFT GAS
Amana ARG3600LL RANGE- S/C S/I DDRAFT GAS
Amana ARG3600W RANGE- S/C S/I DDRAFT GAS
Amana ARG3600WW RANGE- S/C S/I DDRAFT GAS
Amana ARG3601L RANGE- S/C S/I DDRAFT GAS
Amana ARG3601LL RANGE- S/C S/I DDRAFT GAS
Amana ARG3601W RANGE- S/C S/I DDRAFT GAS
Amana ARG3601WW RANGE- S/C S/I DDRAFT GAS
Whirlpool ARG483WP01 Refrigerators*
Whirlpool ARG490 REFRIGERATOR
Whirlpool ARG4901 SIDE-BY-SIDE REFRIGERATOR
Amana ARG7102C RANGE- S/C S/I DDRAFT GAS
Amana ARG7102L RANGE- S/C S/I DDRAFT GAS
Amana ARG7102L RANGE- S/C F/S GAS
Amana ARG7102L Range - S/c S/i Ddraft Gas
Amana ARG7102W RANGE- S/C F/S GAS
Amana ARG7102W RANGE- S/C S/I DDRAFT GAS
Amana ARG7200L RANGE- S/C S/I DDRAFT GAS
Amana ARG7200W RANGE- S/C S/I DDRAFT GAS
Amana ARG7202 E RANGE- S/C S/I DDRAFT GAS
Amana ARG7300LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7300W RANGE- S/C S/I DDRAFT GAS
Amana ARG7300WW RANGE- S/C S/I DDRAFT GAS
Amana ARG7301L RANGE- S/C S/I DDRAFT GAS
Amana ARG7301LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7301W RANGE- S/C S/I DDRAFT GAS
Amana ARG7301WW RANGE- S/C S/I DDRAFT GAS
Amana ARG7302CC RANGE- S/C S/I DDRAFT GAS
Amana ARG7302LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7302WW RANGE- S/C S/I DDRAFT GAS
Amana ARG7303CC RANGE- S/C F/S GAS
Amana ARG7303LL RANGE- S/C F/S GAS
Amana ARG7303WW RANGE- S/C F/S GAS
Amana ARG7600CC RANGE- S/C S/I DDRAFT GAS
Amana ARG7600L RANGE- S/C S/I DDRAFT GAS
Amana ARG7600L RANGE- S/C F/S GAS
Amana ARG7600LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7600W RANGE- S/C S/I DDRAFT GAS
Amana ARG7600WW RANGE- S/C S/I DDRAFT GAS
Amana ARG7600WW RANGE- S/C F/S GAS
  #2 (permalink)
Old 11-03-2011, 09:41 AM
Banned
Chris_Polk is on a distinguished road
Default E20 Error code
"E20" error code on these units mean the water is not pumping out fast enough. Typically technicians would do the following:
1. Check the drain hose for restrictions. Restriction, correct problem. No restriction, go to step (2).
2. Start the washer and check for 120VAC at the drain pump.
Zero, replace the Main Control Board. 120VAC, remove the pump and check it for blockage. If blocked, remove the restriction, if not, replace the pump.
As you can tell this is not a DIY type of job. I would suggest to contact your manufacturer for some assistance.
  #3 (permalink)
Old 11-03-2011, 09:50 AM
Junior Member
Default
Chris, thanks for the information. Yes, not something I would be able to do. I opened the back access panel to look inside. Thinking that I could pull off the hose from the tub to the pump and try and clean out the catch basket/filter. I can't even get my hands in the right orientation with the pliers and or nut driver to loosen the clamps and screw. I ran the unit on the spin cycle and it ran through the cycle and actually pumped out the remaining water from the previous faulty cycle. Sounds like it is pumping the water out with good pressure. I guess I need to call a technician in and spend $400 on a 4 year old washer.
  #4 (permalink)
Old 11-03-2011, 12:10 PM
Banned
Default
Try contacting the manufacturer. They do tend to have some parts on a limited part warranty and may be able to help you with the cost. Or see if you can get a discount on purchasing a new unit of theirs. This sometimes is an option, if you ask, and if you go to purchase a new unit. Sometimes purchasing new is much cheaper than repairing, plus you get a new warranty. Just my food for thought!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Affinity error code 68 ericdiy Washer Repair 12 02-14-2013 08:35 PM
Frigidaire Affinity error code E68 ericdiy Washer Repair 1 05-21-2011 02:45 PM
Error Code E04 on Frigidaire Affinity Dryer Soarer Dryer Repair 3 02-23-2011 06:18 AM
frigidaire affinity E62 error code seejayo Washer Repair 4 01-29-2011 11:56 AM
Frigidaire Affinity dryer error code E9E jpalazzi Dryer Repair 4 04-24-2010 03:20 PM
