Discuss
GE Washer Help Needed
 in
Washer Repair
Washer will start to aggitate or spin on spin cycle for about 30 seconds and then the motor just stops.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Washer Help Needed
  #1 (permalink)
Old 12-11-2007, 10:55 PM
mrhogiyogi mrhogiyogi is offline
Junior Member
mrhogiyogi is on a distinguished road
Default GE Washer Help Needed
Model Number: WPSR3090   Brand: GE   Age: 5 - 10 years
Washer will start to aggitate or spin on spin cycle for about 30 seconds and then the motor just stops. It smells like something is getting hot. After it is allowed to sit for 5 min it will do the same thing again start and then quit. Some help please
Don
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-12-2007, 12:15 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem with your washer is a bad motor.
Remove the front panel to get access to the motor. It is a good idea to replace the belt at the same time.
- The part number for the motor AP3160670
- The part number for the belt AP2044592
- Here are the break down diagrams for the GE washer Model WPSR3090V1WW
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washing Machine Help Needed ADMIRAL Washer Repair 1 12-07-2007 04:02 PM
Microwave repair advice needed dalek Microwave Repair 2 11-27-2007 02:02 PM
Parts needed? Brad Culp Dryer Repair 3 11-16-2007 01:57 PM
25A 277V AC heater switch needed AaronLorr Heating, Ventilation, and Air Conditioning (HVAC) 3 11-12-2007 05:15 PM
Troubleshooting Help Needed bobar Oven Repair (including Ranges and Cooktops) 2 11-10-2007 08:50 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
