After the power problems on the east coast my power was restored and when it was my Kenmore washer does not function. I get a door locked light only. I can not get it to start or do anything. Is there a reset for this? Is this an indication of a blown fuse? I have not done anything except verify there is 115 at outlet. After pushing a combination of buttons there are different lights lit up. I assume this is some kind of diagnostic tool. I cannot seem to find the schematic on line anywhere.
Take off the lower service panel and you should find some tech notes inside that will tell you how to interpret the error codes and how to test components. The likely problem is the control unit, so focus there.
