My frt. load washer does not drain completely. I have to connect my wet dry vac to the drain hose on the back of the machine and I always get about a quart of water. I recently changed out the pump and it didn't help. It takes most of the water out during the final spin cycle but still leaves about a quart.
If you changed out the pump then it seems like something is lodged in the drain hoses. Check them out and see if that fixes the problem.
