Discuss
Kenmore Front Loader wont spin
 in
Washer Repair
My Kenmore Front Loader doesn't spin anymore, we noticed clothes coming out wetter than normal then soak and wet. I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Front Loader wont spin
  #1 (permalink)
Old 05-14-2009, 09:34 AM
Junior Member
corrales is on a distinguished road
Question Kenmore Front Loader wont spin
Model Number: 417.441023200   Brand: Kenmore   Age: 1 - 5 years
My Kenmore Front Loader doesn't spin anymore, we noticed clothes coming out wetter than normal then soak and wet. I watched the machine cycle through a load and noticed it never would spin. I removed back panel to look for damage and found the left shock absorber broken off. No other visual damage mechanical or electrical (no wires burnt or disconected). Replaced shock absorber and still same problem. Water fills and drains and door lock light is on as normal. Belt on motor is fine. Can hear the clicking of the switches on Final Spin cycle when it should be spinning clockwise and then counter clockwise just not movement after the clicks and the cycle quickly moves to the end of wash cycle where normally it takes 10 min or so. Not sure what else to check? Thanks for any advice.
Ads By Google
Related Models
Kenmore 417.59012890  GAS DRYER
Kenmore 417.69042990  KENMORE DRYER
Kenmore 417.69042991  DRYER
Kenmore 417.69052990  DRYER
Kenmore 417.69052991  ELECTRIC DRYER
Kenmore 417.79042990  DRYER
Kenmore 417.79042991  DRYER
Kenmore 417.79052990  DRYER
Kenmore 417.79052991  DRYER
Kenmore 417.80032990  DRYER
Kenmore 417.80042990  DRYER
Kenmore 417.80042991  DRYER
Kenmore 417.80052990  DRYER
Kenmore 417.80052991  DRYER
Kenmore 417.80142000  DRYER
Kenmore 417.81042000  DRYER
Kenmore 417.81042001  DRYER
Kenmore 417.81052000  ELECTRIC DRYER
Kenmore 417.81052001  DRYER
Kenmore 417.81142000  DRYER
Kenmore 417.81142001  DRYER
Kenmore 417.82042100  DRYER
Kenmore 417.82042101  DRYER
Kenmore 417.82042102  SEARS/DRYER
Kenmore 417.82052100  DRYER
Kenmore 417.82052101  DRYER
Kenmore 417.82052102  DRYER
Kenmore 417.82052103  SEARS/ELECTRIC DRYER
Kenmore 417.82142100  DRYER
Kenmore 417.82142101  DRYER
Kenmore 417.82142102  SEARS/ELECTRIC DRYER
Kenmore 417.83042200  SEARS/DRYER
Kenmore 417.83042201  SEARS/ELECTRIC DRYER
Kenmore 417.83052200  SEARS/DRYER
Kenmore 417.83052201  SEARS/DRYER
Kenmore 417.83142200  SEARS/DRYER
Kenmore 417.83142201  SEARS/ELECTRIC DRYER
Kenmore 417.88988100  ELECTRIC DRYER
Kenmore 417.88988800  ELECTRIC DRYER
Kenmore 417.88989100  GAS DRYER
Kenmore 417.88989800  GAS DRYER
Kenmore 417.89090100  WASHER DRYER COMBINATION
Kenmore 417.89090110  COMBINATION WASHER-DRYER
Kenmore 417.89090200  WASHER DRYER COMBINATION
Kenmore 417.89090210  COMBINATION WASHER-DRYER
Kenmore 417.89090400  WASHER DRYER COMBINATION
Kenmore 417.89090410  COMBINATION WASHER-DRYER
Kenmore 417.89090600  WASHER DRYER COMBINATION
Kenmore 417.89090610  COMBINATION WASHER-DRYER
Kenmore 417.89090800  WASHER DRYER COMBINATION
Kenmore 417.89090810  COMBINATION WASHER-DRYER
Kenmore 417.90032990  DRYER
Kenmore 417.90042990  DRYER
Kenmore 417.90042991  DRYER
Kenmore 417.90052990  DRYER
Kenmore 417.90052991  DRYER
Kenmore 417.90142000  DRYER
Kenmore 417.90802990  LAUNDRY CENTER
Kenmore 417.90802991  LAUNDRY CENTER
Kenmore 417.90802992  LAUNDRY CENTER
Kenmore 417.90807990  LAUNDRY CENTER
Kenmore 417.90812990  LAUNDRY CENTER
Kenmore 417.90812991  LAUNDRY CENTER
Kenmore 417.90812992  LAUNDRY CENTER
Kenmore 417.90814000  LAUNDRY CENTER
Kenmore 417.90814001  LAUNDRY CENTER
Kenmore 417.90814002  LAUNDRY CENTER
Kenmore 417.90817990  LAUNDRY CENTER
Kenmore 417.90862990  LAUNDRY CENTER
Kenmore 417.90862991  LAUNDRY CENTER
Kenmore 417.90862992  LAUNDRY CENTER
Kenmore 417.90872990  LAUNDRY CENTER
Kenmore 417.90872991  LAUNDRY CENTER
Kenmore 417.90872992  LAUNDRY CENTER
Kenmore 417.91042000  DRYER
Kenmore 417.91042001  DRYER
Kenmore 417.91052000  GAS DRYER
Kenmore 417.91052001  DRYER
Kenmore 417.91142000  DRYER
Kenmore 417.91142001  DRYER
Kenmore 417.91702000  LAUNDRY CENTER
Kenmore 417.91702001  LAUNDRY CENTER
Kenmore 417.92042100  DRYER
Kenmore 417.92042101  DRYER
Kenmore 417.92042102  SEARS/GAS DRYER
Kenmore 417.92052101  DRYER
Kenmore 417.92052102  DRYER
Kenmore 417.92052103  SEARS/GAS DRYER
Kenmore 417.92142100  DRYER
Kenmore 417.92142101  DRYER
Kenmore 417.92142102  SEARS/GAS DRYER
Kenmore 417.92702200  LAUNDRY CENTER
Kenmore 417.93042200  SEARS/DRYER
Kenmore 417.93042201  SEARS/DRYER
Kenmore 417.93052200  SEARS/DRYER
Kenmore 417.93052201  SEARS/DRYER
Kenmore 417.93142200  SEARS/DRYER
Kenmore 417.93142201  SEARS/DRYER
Kenmore 417.93702200  LAUNDRY CENTER
Kenmore 417.93802200  LAUNDRY CENTER
Frigidaire 41739012890 Frg(v0) / Washer
Frigidaire 41739012891
Frigidaire 41739022890 Frg(v0) / Washer
Frigidaire 41739022891 Frg/washer
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41784988100 AUTOMATIC WASHER
Kenmore 41784988800 AUTOMATIC WASHER
Kenmore 41789190100 COMBINATION WASHER/DRYER
Kenmore 41789190110 COMBINATION WASHER/DRYER
Kenmore 41789190120 COMBINATION WASHER/DRYER
Kenmore 41789190600 COMBINATION WASHER/DRYER
Kenmore 41789190610 COMBINATION WASHER/DRYER
Kenmore 41789190620 COMBINATION WASHER/DRYER
Kenmore 41789190800 COMBINATION WASHER/DRYER
Kenmore 41789190810 COMBINATION WASHER/DRYER
Kenmore 41789190820 COMBINATION WASHER/DRYER
Kenmore 41789195100 COMBINATION WASHER/DRYER
  #2 (permalink)
Old 05-15-2009, 06:59 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Can you tell us if the washer is spinning after the wash cycle? It sounds like it is only spinning after the rinse cycle for the final spin.
Your broken shock may have caused another part to fail, but before speculating on that please tell us exactly how the machine behaves from beginning to end and we can be a little more accurate in the diagnoses.
__________________
  #3 (permalink)
Old 05-15-2009, 06:04 PM
Junior Member
Default
Machine was not spinning at all during any cycle. Found the problem to be the motor control board. First tried the door lock, replaced and still same problem, put in old one and new control board and she kicked started back up. Expensive repair though at $199 had to purchase locally as time was of the essence, family running out of clean clothes! Thx for the reply and I hope this thread helps somebody with similiar problem.
  #4 (permalink)
Old 05-16-2009, 06:55 AM
Senior Expert
APP Volunteer
Default
Well, glad you got it fixed. I thought that's where you might be headed but since we are not present I always want to have as much info as possible before recommending an expensive repair.
Thanks for updating us, and good luck with your machine.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenomre front loader wont final spin CNR Washer Repair 14 04-01-2010 11:59 AM
Front loader wont spin robnrobn2000 Washer Repair 1 01-04-2010 12:30 PM
Kenmore Front Loader wont spin in any cycle gerac Washer Repair 4 07-27-2009 08:57 AM
Kenmore front loader wont agitate or spin bcarroll55 Washer Repair 2 12-22-2008 08:10 PM
front loader wont spin n1ktc Washer Repair 6 11-09-2008 10:18 AM
