| » Roper washer will not spin, agitate, pump |
Model Number: RAS8445KQ0 Brand: Roper Age: 1 - 5 years
After several loads of laundry yesterday, our washer locked up. We noticed that you could hear the motor hum, but nothing was moving. It must have stopped mid-cycle. There was still water in the tub. It will fill, but it will not wash, spin, or drain. I am not able to move the tub or agitator by hand.
Please advise. Ads By Google Related Models |
Remove the cabinet to get access to the washer parts.
Remove the pump and the motor. Start the washer to see if the motor will run. Post your findings, please. You can find the complete instructions how to remove the cabinet, the pump and the motor in the service manual. - Here are the break down diagrams for the Roper washer Model RAS8445KQ0 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
In such situation it could be two things: the transmission is stuck or the pump is stuck.
Install the motor back in place but do not install the pump. Start the washer and see how it agitates. Bypass the lid switch and check the spin. If there is nothing wrong, install the pump back and run the same tests. Post your findings, please. Gene.
__________________
In such case I would recommend to replace the pump because a foreign object inside can cause a water leak.
- The part number for the pump AP2907492 Gene.
__________________
HI, MY ROPER WASHER ALLOWS ME TO FILL IT FROM THE HOT SIDE ONLY. WHEN I TRY TO FILL IT FROM THE COLD SIDE IT ONLY MAKES A LOW TONE HUMMING SOUND. WHEN I SWITCH THE CONTROLS TO SPIN IT DOES THE SAME THING.
In order to provide the most accurate advise I need the complete model number of the washer. You can find it under the lid.
Post in as a new thread, please. Best regards. Gene.
__________________
I have the same washer with the same problem. Turns out my lid safety switch dropped out of rim. sse where plastic plunger goes into space? I have ordered the part from roper, but they won't tell me how to open the top to replace it. I emptied my washer by manually presswing the switch.
Posr it as a new thread, please. Gene.
__________________
| Display Modes | |
| Washer will not agitate but will pump and spin | wor96 | Washer Repair | 6 | 08-02-2009 01:30 PM |
| GE topload will not agitate/spin will pump | Alizabeth | Washer Repair | 1 | 02-23-2009 06:09 PM |
| kenmore 70 series washer will not agitate/spin + rusty drive shaft/pump | pkme | Washer Repair | 2 | 01-27-2009 07:55 AM |
| Roper will not agitate and spin | RDSandy | Washer Repair | 1 | 01-28-2008 04:32 PM |
| Roper will not agitate or spin | RDSandy | Washer Repair | 0 | 01-26-2008 07:14 AM |
