Discuss
Kenmore Series 90 Won't Spin
 in
Washer Repair
I've read several threads on this. I don't think it is the lid switch as I've used a screw driver
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Series 90 Won't Spin
  #1 (permalink)
Old 10-30-2011, 12:59 PM
Junior Member
tom@poole.com is on a distinguished road
Default Kenmore Series 90 Won't Spin
Model Number: 11020902990   Brand: Kenmore   Age: More than 10 years
I've read several threads on this. I don't think it is the lid switch as I've used a screw driver to manually activate the spin cycle. It sounds like I may need to check the hoses to see if they are kinked. Unfortunately, I don't know where those hoses are. It sounds like they are inside the washer - not the hoses that are external.
Any help would be most appreciated!
Related Models
Kenmore 11020902990 AUTOMATIC WASHER
Kenmore 11020902991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020904990 AUTOMATIC WASHER
Kenmore 11020904991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020907990 AUTOMATIC WASHER
Kenmore 11020907991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020912990 AUTOMATIC WASHER
Kenmore 11020912991 WASHER
Kenmore 11020922990 AUTOMATIC WASHER
Kenmore 11020922991 WASHER
Kenmore 11020924990 AUTOMATIC WASHER
Kenmore 11020924991 WASHER
Kenmore 11020927990 AUTOMATIC WASHER
Kenmore 11020932990 AUTOMATIC WASHER
Kenmore 11020932991 AUTOMATIC WASHER
Kenmore 11020932992 AUTOMATIC WASHER
Kenmore 11020932993 WASHER
Kenmore 11020932994 WASHER
Kenmore 11020936990 AUTOMATIC WASHER
Kenmore 11020936991 AUTOMATIC WASHER
Kenmore 11020936992 AUTOMATIC WASHER
Kenmore 11020936993 WASHER
Kenmore 11020936994 WASHER
Kenmore 11020942990 AUTOMATIC WASHER
Kenmore 11020942991 AUTOMATIC WASHER
Kenmore 11020942992 AUTOMATIC WASHER
Kenmore 11020942993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020942994 WASHER
Kenmore 11020952990 AUTOMATIC WASHER
Kenmore 11020952991 AUTOMATIC WASHER
Kenmore 11020952992 AUTOMATIC WASHER
Kenmore 11020952993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020952994 WASHER
Kenmore 11020954992 AUTOMATIC WASHER
Kenmore 11020954993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020954994 WASHER
Kenmore 11020956990 AUTOMATIC WASHER
Kenmore 11020956991 AUTOMATIC WASHER
Kenmore 11020956992 AUTOMATIC WASHER
Kenmore 11020956993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020956994 WASHER
Kenmore 11020957990 AUTOMATIC WASHER
Kenmore 11020957991 AUTOMATIC WASHER
Kenmore 11020957992 AUTOMATIC WASHER
Kenmore 11020972990 WASHER
Kenmore 11020972991 WASHER
Kenmore 11020972992 WASHER
Kenmore 11020972993 WASHER
Kenmore 11020982990 WASHER
Kenmore 11020982991 WASHER
Kenmore 11020982992 WASHER
Kenmore 11020982993 WASHER
Kenmore 11020992990 WASHER
Kenmore 11020992991 WASHER
Kenmore 11020992992 WASHER
Kenmore 11020992993 WASHER
Kenmore 11020994991 WASHER
Kenmore 11020994992 WASHER
Kenmore 11020994993 WASHER
Kenmore 11020996991 WASHER
Kenmore 11020996992 WASHER
Kenmore 11020996993 WASHER
Kenmore 11020997990 WASHER
Kenmore 11020997991 WASHER
Kenmore 11020997992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021102010 AUTOMATIC WASHER
Kenmore 11021102011 AUTOMATIC WASHER
Kenmore 11021112010 AUTOMATIC WASHER
Kenmore 11021112011 AUTOMATIC WASHER
Kenmore 11021182010 AUTOMATIC WASHER
Kenmore 11021182011 AUTOMATIC WASHER
Kenmore 11021202010 AUTOMATIC WASHER
Kenmore 11021202011 AUTOMATIC WASHER
Kenmore 11021252110 AUTOMATIC WASHER
Kenmore 11021292010 AUTOMATIC WASHER
Kenmore 11021292011 AUTOMATIC WASHER
Kenmore 11021302010 AUTOMATIC WASHER
Kenmore 11021302011 AUTOMATIC WASHER
Kenmore 11021352110 AUTOMATIC WASHER
Kenmore 11021392010 AUTOMATIC WASHER
Kenmore 11021392011 AUTOMATIC WASHER
Kenmore 11021392012 AUTOMATIC WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
Kenmore 11022032101 WASHER
Kenmore 11022032102 AUTOMATIC WASHER
Kenmore 11022036100 WASHER
Kenmore 11022036101 WASHER
Kenmore 11022036102 AUTOMATIC WASHER
Kenmore 11022042100 WASHER
Kenmore 11022042101 WASHER
Kenmore 11022042102 AUTOMATIC
Kenmore 11022052100 WASHER
Kenmore 11022052101 WASHER
Kenmore 11022052102 AUTOMATIC WASHER
Kenmore 11022054100 WASHER
Kenmore 11022054101 WASHER
Kenmore 11022054102 AUTOMATIC WASHER
Kenmore 11022056100 WASHER
Kenmore 11022056101 WASHER
Kenmore 11022056102 AUTOMATIC WASHER
Kenmore 11022062100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022062101 WASHER
  #2 (permalink)
Old 10-31-2011, 05:41 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
If it will not drain then it is probably the lid switch. If it drains and will not spin, check the clutch.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 80 series will not spin mkeaton Washer Repair 1 09-02-2011 04:58 PM
Kenmore 90 series won't spin on its own andyloeb Washer Repair 1 10-30-2010 05:46 PM
Kenmore 80 Series won't spin Kristine Washer Repair 6 08-01-2010 11:21 PM
Kenmore 90 Series no spin mfalkevitz Washer Repair 1 10-02-2009 03:35 AM
kenmore series 80 will not spin tlgeirna Washer Repair 1 06-04-2008 02:51 AM
