| » Esate Whirlpool Washer-timer stops once it hits rinse and i manually move to spin |
Model Number: TAWX400RQ2 Brand: Estate Age: 1 - 5 years
Our washer works fine until it reaches the rinse mode. Then it stops and we have to manually move the timer to spin, but our clothes is not being rinsed. Very little water comes out once it hits rinse and then stops completely but little water fremains to come out.
Can you clarify the situation. It sounds like your machine will fill, agitate, drain, spin and then stop when it reaches the rinse cycle without filling for the rinse. You then move the timer to spin after rinse and it will spin and finish. Is this correct? If not please tell us in detail exactly what is happening and we can probably come up with some suggestions.
__________________
Ok, thanks
Given that it fills, agitates, drains and spins in the wash cycle that would suggest that all of the mechanical systems are ok. This leaves the timer. Fortunately this is one of the least expensive timers, so while I cannot guarantee this will fix it, the probability is high and the expense is low, so I would suggest you go ahead and replace it. Here is your part Replacement parts for WHIRLPOOL TAWX400RQ2 | AppliancePartsPros.com Good luck, and let us know what happens.
__________________
| Display Modes | |
| Timer will only advance to fill and wash not drain (have to manually move to drain) | zibdi1 | Dishwasher Repair | 0 | 06-15-2009 03:47 PM |
| Not starting automatically must move timer switch manually | mybuddy101 | Dishwasher Repair | 0 | 01-31-2009 07:44 AM |
| Whirlpool washer stops, restarts when timer is advanced manually | derr | Washer Repair | 2 | 01-21-2009 09:44 AM |
| washer/water shuts off when hits all rinse cycles | c4cdlm | Washer Repair | 7 | 12-17-2008 02:46 PM |
| whirlpool washer won't spin manually or spin | boniam | Washer Repair | 15 | 06-29-2008 07:19 AM |
