Discuss
kenmore/whirlpool spins slowly.
 in
Washer Repair
My old washer won't spin fast enough to dry the clothes. There are oil drops on all the lower
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kenmore/whirlpool spins slowly.
  #1 (permalink)
Old 12-11-2007, 09:39 AM
scirocco90 scirocco90 is offline
Junior Member
scirocco90 is on a distinguished road
Default kenmore/whirlpool spins slowly.
Model Number: C1104430081   Brand: Whirlpool   Age: More than 10 years
My old washer won't spin fast enough to dry the clothes. There are oil drops on all the lower parts of the transmission. The solenoid seems to work. I was able to spin it freely by hand, but it slows back down to a slow spin. The set screw seems to be tight. Has the transmission gone, or just a seal?
Related Models
Hoover C1111--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1119--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1119080 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1121--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1123--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1125--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Jenn-Air C116 Surface Unit - Ddraft Ele
Jenn-Air C116-C Surface Unit - Ddraft Ele
Amana C11B Freezer - Chest
Amana C11B-A Freezer - Chest
Amana C11B-C Freezer - Chest
Amana C11B-G Freezer - Chest
Amana C11B-L Freezer - Chest
Amana C11F Freezer - Chest
Amana C11F-A Freezer - Chest
Amana C11F-AG Freezer - Chest
Amana C11F-C Freezer - Chest
Amana C11W Freezer - Chest
Amana C11W-A Freezer - Chest
Amana C11W-AG Freezer - Chest
Amana C11W-C Freezer - Chest
Amana C122B Room Air Conditioner
Maytag C12HE  Freezer - Chest
Maytag C12HS  Freezer - Chest
Maytag C12J Freezer - Chest
Thermador C12M
Hoover C1401--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1403--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1404--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1405--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1407--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1409910 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1411930 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1412-900
Hoover C1413930 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1414900 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1415--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1417903 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1425--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1429--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Amana C142B Room Air Conditioner
Hoover C1431--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1433--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1439--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1498--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1498020 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1499--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1499020 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Amana C15 Freezer - Chest
Amana C150DW Freezer - Chest
Amana C150FW Freezer - Chest
Hoover C1515--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Amana C151DW Freezer - Chest
Amana C151FW Freezer - Chest
Hoover C1525--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1527--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1529--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Maytag C15AALWH Freezer - Chest
Maytag C15ABLWH Freezer - Chest
Amana C15B Freezer - Chest
Amana C15B-1 Freezer - Chest
Amana C15B-1-A Freezer - Chest
Amana C15B-1-C Freezer - Chest
Amana C15B-1-G Freezer - Chest
Amana C15B-1-L Freezer - Chest
Amana C15B-A Freezer - Chest
Amana C15B-C Freezer - Chest
Amana C15B-G Freezer - Chest
Amana C15B-L Freezer - Chest
Amana C15B1 Freezer - Chest
Amana C15B1L Freezer - Chest
  #2 (permalink)
Old 12-11-2007, 04:59 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
In order to provide the most accurate advise I need the complete model number of the washer. The number you posted is the serial number.
Would it stop spinning if you hold the basket?
__________________
  #3 (permalink)
Old 12-11-2007, 06:28 PM
Junior Member
Default
it says model #C1104430081 there is a small space between the 0 and the 4 and the 4430081 is a little smaller. Serial #AC 22147. This is a Canadian washer. The C might denote Canada? It was made by Whirlpool for Kenmore. Yes the basket stops if I hold it.
  #4 (permalink)
Old 12-11-2007, 06:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad transmission.
Unfortunately the APP does not ship parts to Canada.
__________________
  #5 (permalink)
Old 12-11-2007, 07:07 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
make sure the belt is tight,make sure that the set screw is flush with the outer part.If so then look under and see the spring that holds the clutch plate down, remove the spring and take out a spacer[washer] then replace the spring and then check the spin.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag dryer drying slowly stodtmeister Dryer Repair 3 12-12-2007 06:12 PM
Tub Spins While Agitating icoetmartyp Washer Repair 0 12-07-2007 11:42 PM
Gas Oven Heats Up Too Slowly zevfix Oven Repair (including Ranges and Cooktops) 2 11-21-2007 09:15 PM
Dryer Drum Turns Slowly BETA270 Dryer Repair 4 10-24-2007 03:14 PM
Washer will spin slowly but not drain Mikie Martin Washer Repair 0 07-31-2007 08:36 AM
