Discuss
Water leaks out of pump housing
 in
Washer Repair
GE washer is leaking through small hole in plastic pump assembly when agitating.The hole looks to be a refief
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Water leaks out of pump housing
  #1 (permalink)
Old 12-11-2007, 09:29 AM
bobtubbert@netzero.net bobtubbert@netzero.net is offline
Junior Member
bobtubbert@netzero.net is on a distinguished road
Default Water leaks out of pump housing
Model Number: wwa8330galad   Brand: GE   Age: More than 10 years
GE washer is leaking through small hole in plastic pump assembly when agitating.The hole looks to be a refief port. Do I need to replace the hole pump assembly?Is this a difficult job? Thank You
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-11-2007, 04:21 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
This is one of the most common problem with such pumps.
It's going to be worse and worse and it's better to replace the pump.
The job is not very complicated. You have to remove the back cover to access the pump. The pump is mounted with four screws and the new pump comes with new screws. The pump is connected to the motor with the coupling (#601 on the #1 break down diagram).
- The part number for the pump AP2046344
- Here are the break down diagrams for the GE washer Model WWA8330GAL
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool water filter housing cathyjp7 Refrigerator & Freezer Repair 0 11-25-2007 01:19 PM
Leaks water rchildress2 Washer Repair 1 11-23-2007 10:52 AM
Water leaks Gustavo Washer Repair 0 11-23-2007 10:01 AM
Injector hose leaks when water pressure is low edpinarello Washer Repair 0 08-11-2007 12:13 AM
refridgerator leaks water from inside kmape Refrigerator & Freezer Repair 1 07-30-2007 11:40 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
