Discuss
washing machine
 in
Washer Repair
Just Installed New Belt.had Problem Keeping Belt In Center Of Pully.will This Adjust Itself,or Do I Still
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washing machine
  #1 (permalink)
Old 12-10-2007, 07:39 PM
Donald Belanger Donald Belanger is offline
Junior Member
Donald Belanger is on a distinguished road
Default washing machine
Model Number: GLTF1670ASO   Brand: Frigidaire   Age: 5 - 10 years
Just Installed New Belt.had Problem Keeping Belt In Center Of Pully.will This Adjust Itself,or Do I Still Have Other Problems?don't Know If Belt Is Properly Insalled. Thanks,donald
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-10-2007, 07:55 PM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
The belt will self adjust on front load washers. If it hangs over the front or the rear of the large pulley, just move it in the opposite direction on the small pulley to correct it unit it is centered on the large pulley.
TechnicianBrian
  #3 (permalink)
Old 12-11-2007, 04:26 PM
Junior Member
Default
Belt Stayed On About 3 Loads Of Wash,then Sliped Of,also Noticed Rubbing Marks Inside.think I Have Bad Bearing.
  #4 (permalink)
Old 12-11-2007, 04:46 PM
Senior Expert
APP Volunteer
Default
You want to take hold of the basket assembly and try moving it within the tub to check for bearing wear. It should not move top to bottom,side to side, or front to rear at all. If you can move it up and down, or side to side, the bearing is bad and you will need to replace the rear tub assembly (the bearing comes with it) and possibly the basket spider depending on how worn it is.
TechnicianBrian
  #5 (permalink)
Old 12-11-2007, 07:32 PM
Junior Member
Default
Thank's Brian,maybe Time To Replace. Donald
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washing Machine NIKKIMAN13 Washer Repair 0 11-17-2007 02:18 PM
GE Washing Machine Billk Washer Repair 1 11-11-2007 05:07 PM
washing machine jadesue Washer Repair 0 11-10-2007 02:46 PM
washing machine takes hours to finish washing a load kelly Monday Washer Repair 2 09-26-2007 03:42 AM
GE washing machine paul Washer Repair 2 07-19-2007 08:13 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
