Discuss
Kenmore Elite-water wont shut off, now wont drain
 in
Washer Repair
First problem was when the water would not shut off to go to next cycle. Then the real problem started
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Elite-water wont shut off, now wont drain
  #1 (permalink)
Old 05-12-2009, 11:26 AM
Junior Member
dbigotis is on a distinguished road
Default Kenmore Elite-water wont shut off, now wont drain
Model Number: 11020932992   Brand: Kenmore   Age: 5 - 10 years
First problem was when the water would not shut off to go to next cycle. Then the real problem started when the washer would only agitate and not drain, spin etc. Help, I run a daycare and my washer is a major appliance in my house!!
Related Models
Kenmore 11020932992 AUTOMATIC WASHER
Kenmore 11020932993 WASHER
Kenmore 11020932994 WASHER
Kenmore 11020936990 AUTOMATIC WASHER
Kenmore 11020936991 AUTOMATIC WASHER
Kenmore 11020936992 AUTOMATIC WASHER
Kenmore 11020936993 WASHER
Kenmore 11020936994 WASHER
Kenmore 11020942990 AUTOMATIC WASHER
Kenmore 11020942991 AUTOMATIC WASHER
Kenmore 11020942992 AUTOMATIC WASHER
Kenmore 11020942993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020942994 WASHER
Kenmore 11020952990 AUTOMATIC WASHER
Kenmore 11020952991 AUTOMATIC WASHER
Kenmore 11020952992 AUTOMATIC WASHER
Kenmore 11020952993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020952994 WASHER
Kenmore 11020954992 AUTOMATIC WASHER
Kenmore 11020954993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020954994 WASHER
Kenmore 11020956990 AUTOMATIC WASHER
Kenmore 11020956991 AUTOMATIC WASHER
Kenmore 11020956992 AUTOMATIC WASHER
Kenmore 11020956993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020956994 WASHER
Kenmore 11020957990 AUTOMATIC WASHER
Kenmore 11020957991 AUTOMATIC WASHER
Kenmore 11020957992 AUTOMATIC WASHER
Kenmore 11020972990 WASHER
Kenmore 11020972991 WASHER
Kenmore 11020972992 WASHER
Kenmore 11020972993 WASHER
Kenmore 11020982990 WASHER
Kenmore 11020982991 WASHER
Kenmore 11020982992 WASHER
Kenmore 11020982993 WASHER
Kenmore 11020992990 WASHER
Kenmore 11020992991 WASHER
Kenmore 11020992992 WASHER
Kenmore 11020992993 WASHER
Kenmore 11020994991 WASHER
Kenmore 11020994992 WASHER
Kenmore 11020994993 WASHER
Kenmore 11020996991 WASHER
Kenmore 11020996992 WASHER
Kenmore 11020996993 WASHER
Kenmore 11020997990 WASHER
Kenmore 11020997991 WASHER
Kenmore 11020997992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021102010 AUTOMATIC WASHER
Kenmore 11021102011 AUTOMATIC WASHER
Kenmore 11021112010 AUTOMATIC WASHER
Kenmore 11021112011 AUTOMATIC WASHER
Kenmore 11021182010 AUTOMATIC WASHER
Kenmore 11021182011 AUTOMATIC WASHER
Kenmore 11021202010 AUTOMATIC WASHER
Kenmore 11021202011 AUTOMATIC WASHER
Kenmore 11021252110 AUTOMATIC WASHER
Kenmore 11021292010 AUTOMATIC WASHER
Kenmore 11021292011 AUTOMATIC WASHER
Kenmore 11021302010 AUTOMATIC WASHER
Kenmore 11021302011 AUTOMATIC WASHER
Kenmore 11021352110 AUTOMATIC WASHER
Kenmore 11021392010 AUTOMATIC WASHER
Kenmore 11021392011 AUTOMATIC WASHER
Kenmore 11021392012 AUTOMATIC WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
Kenmore 11022032101 WASHER
Kenmore 11022032102 AUTOMATIC WASHER
Kenmore 11022036100 WASHER
Kenmore 11022036101 WASHER
Kenmore 11022036102 AUTOMATIC WASHER
Kenmore 11022042100 WASHER
Kenmore 11022042101 WASHER
Kenmore 11022042102 AUTOMATIC
Kenmore 11022052100 WASHER
Kenmore 11022052101 WASHER
Kenmore 11022052102 AUTOMATIC WASHER
Kenmore 11022054100 WASHER
Kenmore 11022054101 WASHER
Kenmore 11022054102 AUTOMATIC WASHER
Kenmore 11022056100 WASHER
Kenmore 11022056101 WASHER
Kenmore 11022056102 AUTOMATIC WASHER
Kenmore 11022062100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022062101 WASHER
Kenmore 11022062102 AUTOMATIC WASHER
Kenmore 11022064100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022064101 WASHER
Kenmore 11022064102 AUTOMATIC WASHER
Kenmore 11022066100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022066101 WASHER
Kenmore 11022066102 AUTOMATIC WASHER
Kenmore 11022082100 WASHER
Kenmore 11022082101 AUTOMATIC WASHER
Kenmore 11022082102 AUTOMATIC
Kenmore 11022084100 WASHER
Kenmore 11022084101 AUTOMATIC WASHER
Kenmore 11022084102 AUTOMATIC
Kenmore 11022086100 WASHER
Kenmore 11022086101 AUTOMATIC WASHER
  #2 (permalink)
Old 05-12-2009, 04:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would do is check the lid switch. You have to remove the end caps and the screw on the each corner of the control panel. Pull the console forward and up and lay it on its back.Check how the air pressure hose is connected to the water level switch at the same time.
- The part number for the lid switch is AP3020600
- The part number for the water level switch is AP3020315
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite-water wont shut off, now wont drain or spin dbigotis Washer Repair 1 05-12-2009 04:27 PM
kenmore washer 70 series wont spin and drain water foster13019 Washer Repair 1 12-20-2008 01:05 PM
my kenmore elite gas dryer wont heat helpmeoutplz Dryer Repair 8 09-09-2008 05:30 PM
water dispencer wont shut off tazman48169 Refrigerator & Freezer Repair 0 03-11-2008 02:29 PM
Kenmore Elite just beeps wont run pdwaken Dryer Repair 5 01-25-2008 09:17 PM
