judithbenedict
#1 Posted : Tuesday, May 12, 2009 10:08:22 AM(UTC)
judithbenedict
My washing machine runs fine except that I've discovered that the agitation speed is the same if it is on delicate or regular indicationg that the stronger agitation speed isn't functioning. Any idea what the problem could be or what part might be needed? Thanks.
sidfink43
#2 Posted : Thursday, May 14, 2009 4:22:15 PM(UTC)
sidfink43
Here is the service manual for your machine.
The most likely culprit is your speed selection switch, which is an easy change out. But take a look at the manual and see if you have some other questions before you go that route, and if you do post back to us.
Good luck and keep us updated.
http://www.servicematters.com/m...ibrary/docs/16023083.pdf
kenmore 80 series agitation problem (Washer Repair)
by ccollinswestdyke 11/10/2014 6:47:16 AM(UTC)
Amana Agitation Problem (Washer Repair)
by mustangcoupe69 10/23/2014 7:18:42 PM(UTC)
Kenmore Series 90 - Agitation problem (Washer Repair)
by jimkNJ 2/25/2013 6:14:32 AM(UTC)
kenmore 110 agitation problem (Washer Repair)
by garybirnhak 12/19/2012 6:16:09 AM(UTC)
Kenmore Agitation Problem (Washer Repair)
by dfyfe 7/11/2012 5:27:29 AM(UTC)
Maytag Agitation problem (Washer Repair)
by bevans118 12/6/2010 4:08:11 PM(UTC)
Kenmore Washer Agitation Problem (Washer Repair)
by garyz 12/8/2009 8:09:19 AM(UTC)
by mrs54528 10/26/2009 1:50:15 PM(UTC)
Kenmore washer 110.28822790 agitation problem. (Washer Repair)
by acillatem 3/1/2009 10:29:42 AM(UTC)
Ge Washer Agitation Problem (Washer Repair)
by joedey 4/28/2008 2:31:27 PM(UTC)
Intermitent motor prblem or agitation problem? (Washer Repair)
by racer7696@msn.com 11/25/2007 12:29:59 PM(UTC)
