Discuss
Washer will not fill
 in
Washer Repair
Washer was working fine,but the next day it would not fill. All other cycles work fine just no water.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will not fill
  #1 (permalink)
Old 12-10-2007, 06:11 PM
roddude32 roddude32 is offline
Junior Member
roddude32 is on a distinguished road
Default Washer will not fill
Brand: Roper   Age: 5 - 10 years
Washer was working fine,but the next day it would not fill. All other cycles work fine just no water. it started out it would fill on small load but not on large load,now it will not fill at all. any ideas what I should look for?
Thanks in advance!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-11-2007, 02:07 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would do is check the coils on the water inlet valve and power to the water inlet valve.
In order to provide the most accurate advise I need the complete model number of the washer.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-11-2007, 06:59 PM
Junior Member
Default
Hi Gene, Thanks for the reply. Here is the model number ( RAB4132HQO ) And thanks again,
George
  #4 (permalink)
Old 12-11-2007, 07:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
George
Did you check the coils and the power to the coils?
- Here are the break down diagrams for the Roper washer Model RAB4132HQ0 to help you locate the parts.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer doesn't fill brianv Washer Repair 1 10-24-2007 10:05 PM
Washer will not fill up pssndwy Washer Repair 1 10-24-2007 09:54 PM
washer does not fill completely mitchell Washer Repair 1 10-07-2007 03:16 AM
Washer is slow to fill Dbowls Washer Repair 1 08-30-2007 03:22 PM
GE washer will not fill with water tex Dishwasher Repair 1 08-30-2007 12:33 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
