Discuss
Kenmore not spinning fast enough?
 in
Washer Repair
My Kenmore is leaving clothes wet after final spin. The clothes are not dripping wet, they seem much heavier. Dryer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore not spinning fast enough?
  #1 (permalink)
Old 05-11-2009, 07:42 PM
pdk8 pdk8 is offline
Junior Member
pdk8 is on a distinguished road
Default Kenmore not spinning fast enough?
Model Number: 20702991   Brand: Kenmore   Age: 5 - 10 years
My Kenmore is leaving clothes wet after final spin. The clothes are not dripping wet, they seem much heavier. Dryer is having a tough time drying the clothes. The washer not seeming to spin as fast as when new. I can hold the drum from spinning at start of spin cycle. Does this seem to be a clutch or motor issue or something else? Washer does well in wash mode (moves clothes around well). Brake works very well (stops drum quickly). There is some oil residue at bottom of what seems to be the clutch assembly. Any help would be very much appreciated!
Thank you
Related Models
Amana 2071.004 Mwave - Family Size (60 Hz)
Amana 2072.000 Mwave - Family Size (60 Hz)
Amana 2072.001 Mwave - Family Size (60 Hz)
Amana 2072.002 Mwave - Family Size (60 Hz)
Amana 2072.004 Mwave - Family Size (60 Hz)
Amana 2074.000 Mwave - Family Size (60 Hz)
Amana 2074.001 Mwave - Family Size (60 Hz)
Amana 2074.002 Mwave - Family Size (60 Hz)
Amana 2074.004 Mwave - Family Size (60 Hz)
Whirlpool 2075B0A
Whirlpool 2075B1A
Whirlpool 2075B2A
Whirlpool 2079B00
Whirlpool 2079B10
Whirlpool 2079B20
Whirlpool 2079B30
Whirlpool 2079B40
Amana 2085.000 Mwave - Family Size (60 Hz)
Amana 2085.001 Mwave - Family Size (60 Hz)
Amana 2085.002 Mwave - Family Size (60 Hz)
Amana 2085.004 Mwave - Family Size (60 Hz)
Amana 2089.004 Mwave - Family Size (60 Hz)
Amana 2090.000 Mwave - Family Size (60 Hz)
Amana 2090.001 Mwave - Family Size (60 Hz)
Amana 2090.002 Mwave - Family Size (60 Hz)
Amana 2091.004 Mwave - Family Size (60 Hz)
Amana 2092.004 Mwave - Family Size (60 Hz)
Whirlpool 2092B0A
Whirlpool 2092B1A
Whirlpool 2092B2A
Whirlpool 2092B3A
Amana 2094.004 Mwave - Family Size (60 Hz)
Whirlpool 2095B0A
Whirlpool 2095B1A
Whirlpool 2095B2A
Amana 210-3B Room Air Conditioner
Amana 210-3W
Amana 210-3WH
Hoover 2100 Frigidaire/refrigerator
Amana 21011  Commercial Microwaves
Amana 21016  Commercial Microwaves
Whirlpool 2101W0E
Whirlpool 2101W1E
Whirlpool 2101W2E
Whirlpool 2101^0E
Whirlpool 2101^1E
Whirlpool 2101^2E
Whirlpool 2102W0E
Whirlpool 2102W1E
Whirlpool 2102W2E
Whirlpool 2102^0E
Whirlpool 2102^1E
Whirlpool 2102^2E
Amana 210W-3B Room Air Conditioner
Amana 210W-3BH Room Air Conditioner
Amana 210W-3J Room Air Conditioner
Amana 210W-3JH Room Air Conditioner
Amana 210W-3SP Room Air Conditioner
Amana 210W-3SPF Room Air Conditioner
Amana 210W-3SPFH Room Air Conditioner
Amana 210W-3SPG Room Air Conditioner
Amana 210W-3SPGH Room Air Conditioner
Amana 210W-3SPH Room Air Conditioner
Amana 210W-3W
Amana 210W-3WH
Amana 211-2B
Amana 211-2S
Amana 211-2U
Amana 211-2W
Hoover 2110 Frigidaire/refrigerator
Jenn-Air 21136 Walloven - S/c Ele
Jenn-Air 2113689
Jenn-Air 2113690
Jenn-Air 21137 Walloven - S/c Ele
Jenn-Air 2113788
Whirlpool 2118W30
Whirlpool 2118W40
Whirlpool 2118W50
Whirlpool 2118W60
Whirlpool 2118W70
Whirlpool 2118^30
Whirlpool 2118^40
Whirlpool 2118^50
Whirlpool 2118^60
Whirlpool 2118^70
Amana 212-2J Room Air Conditioner
Amana 212-2J-1 Room Air Conditioner
Amana 212-2JM Room Air Conditioner
Amana 212-2SP Room Air Conditioner
Amana 212-2SPF Room Air Conditioner
Amana 212-2SPG Room Air Conditioner
Amana 212-3J Room Air Conditioner
Amana 212-3J-1 Room Air Conditioner
Amana 212-3S
Amana 212-3SH
Amana 212-3SP Room Air Conditioner
Amana 212-3SPG Room Air Conditioner
Amana 212-3U
Amana 212-3UH
Hoover 2120 White Westinghouse/freezer
Hoover 2120-01 Crosley/dishwasher
Jenn-Air 21238 Walloven - S/c Ele
Jenn-Air 21239 Walloven - S/c Ele
Whirlpool 2126X0A
Whirlpool 2126^0A
Amana 212D-3C
Amana 212D-3CH
Amana 212D-3J Room Air Conditioner
Amana 212D-3JH Room Air Conditioner
Amana 212D-3JM Room Air Conditioner
Amana 212W-3U
Amana 212W-8U
Amana 213-3B Room Air Conditioner
Amana 213-3BH Room Air Conditioner
Amana 213-3E Room Air Conditioner
Amana 213-3F Room Air Conditioner
  #2 (permalink)
Old 05-12-2009, 05:58 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
Sure sounds like the clutch, but before you change it out, disconnect the pump and make certain nothing is blocking the drain line and that the pump is working correctly.
If you conclude that your drain operation is ok, then you can go on to replacing the clutch.
Good luck and let us know how it turns out.
__________________
  #3 (permalink)
Old 05-13-2009, 06:40 PM
Junior Member
Default
Thank you for the reply, I really do not wish to buy a new washer. How can the drain line interfere with the spin cycle? Can it be the transmition? I have seen videos up to the clutch, but none with a clutch removal, is there one out there? Would you change the clutch on a 8 year old machine?
  #4 (permalink)
Old 05-13-2009, 06:53 PM
Senior Expert
APP Volunteer
Default
Ok, sorry I did not explain adequately.
A partial blockage in the drain line and/or pump would not affect the spin, but it would cause your clothes to be wetter than they should and the higher weight of wet clothes could slow down your spin. I wanted you to check the drain in case that was your problem, as it would fix the problem at no cost and save you the time and effort to replace the clutch.
If you determine the drain line is not partially blocked, and it probably is not, then here is your clutch replacement kit.
Part Details - WHIRLPOOL Clutch assembly, part number: 285785
Here is a site that will explain how to replace the clutch. There should also be instructions with the part.
Clutch Replacement on Whirlpool and Kenmore Washers
You should be able to make this repair, just take your time and be careful.
Good luck, and let us know how it turns out.
__________________
  #5 (permalink)
Old 05-13-2009, 06:58 PM
Junior Member
Default
Awesome...I just placed the order. I will let you know what happens.
Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Front Load won't spin fast Erik123 Washer Repair 0 05-01-2009 05:43 PM
Maytag not spinning fast ccrossfr Washer Repair 3 04-10-2009 06:42 PM
kenmore washer does not spin fast TreyinGa Washer Repair 1 03-28-2009 01:58 PM
Kenmore top load washer wont spin fast TreyinGa Washer Repair 2 03-24-2009 05:56 PM
Kenmore Won't spin fast enough imswear Washer Repair 0 07-30-2007 12:13 PM
