Discuss
no water on rinse cycle
 in
Washer Repair
Our washer would not fill with water on the rinse cycle, we called Sears, they wanted $300 to change timer,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » no water on rinse cycle
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-10-2007, 02:56 PM
c4cdlm c4cdlm is offline
Junior Member
c4cdlm is on a distinguished road
Unhappy no water on rinse cycle
Model Number: 110.26934690   Brand: Kenmore   Age: 5 - 10 years
Our washer would not fill with water on the rinse cycle, we called Sears, they wanted $300 to change timer, he told us to order a timer and fix it ourselves. We did and that didn't fix the problem, and several days later the machine won't agitate, it makes a loud clunking noise. What should be try next??
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-10-2007, 07:12 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Regarding the water fill problem during the rinse I would recommend to check the water inlet valve. Check the coil responsible for the cold water for continuity.
Replace the water inlet valve if the coil is open.
Check for 120V coming to this coil when the timer calls for the rinse.
If there is no 120V then check the water temperature switch.
A loud clunking noise instead of the agitation most likely means a bad transmission (aka gear case).
- The part number for the water inlet valve AP3096174
- The part number for the water temperature switch AP3125989
- The part number for the transmission AP3096209
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 12-12-2007, 03:51 PM
Junior Member
Default
we put the old timer back on , and now the machine will agitate, still won't fill on the rinse cycle.
  #4 (permalink)
Old 12-12-2007, 03:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Did you do it?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch dishwasher stuck on rinse cycle JDDrake Dishwasher Repair 2 04-05-2008 10:10 AM
washer keeps repeating the rinse cycle hiltonacres Washer Repair 2 12-13-2007 07:22 PM
Dishwasher won't drain after rinse cycle doityourselfer Dishwasher Repair 9 12-07-2007 01:27 PM
Rinse cycle not functioning properly MarkH Dishwasher Repair 0 11-23-2007 08:26 PM
Dishwasher skips the wash cycle and stops at the rinse cycle jasporo Dishwasher Repair 1 11-16-2007 05:12 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
