Discuss
Water not Draining
 in
Washer Repair
Code appeared on my initial service mode. Checked my pressure switch connection, things looks physically ok, even when I tried
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Water not Draining
  #1 (permalink)
Old 10-26-2011, 08:38 PM
Junior Member
ccino1 is on a distinguished road
Default Water not Draining
Model Number: (P) MAH5500BWQ   Brand: Maytag   Age: 5 - 10 years
Code appeared on my initial service mode. Checked my pressure switch connection, things looks physically ok, even when I tried to suck through the tube...it opens the line. Tried to spin & heard my drain pump sloshing the water but not a whole lot will come out. Time display is not progressively counting down but will go up a notch then down a bit.
Pls. advice and where can I buy the part?
Ads By Google
Related Models
Jenn-Air *A100
Amana /GRILLE Range - S/c S/i Ddraft Gas
Hoover 021 Frigidaire/refrigerator
Hoover 0510
Hoover 0513
Hoover 0515
Hoover 0517-10
Hoover 0517-20
Hoover 0517-30
Hoover 0519
Hoover 0519-10
Hoover 0519-30
Hoover 0519-60 Frigidaire/electric Range
Hoover 0519-70 Frigidaire/electric Range
Hoover 0519-80
Hoover 0610 Frigidaire/freezer
Hoover 0611 White Westinghouse/refrigerator
Hoover 0612 Frigidaire/walloven
Hoover 0613 Frigidaire/freezer
Hoover 0617
Hoover 0617-61 Frigidaire/walloven
Hoover 0617-64 Frigidaire/walloven
Hoover 0620 Frigidaire/walloven
Hoover 0622 Frigidaire/walloven
Hoover 0630 Frigidaire/walloven
Hoover 0632
Hoover 0710 Frigidaire/freezer
Hoover 0750
Whirlpool 0773B10
Whirlpool 0783B10
Hoover 0810
Hoover 0811 Frigidaire/freezer
Hoover 0914 Frigidaire/freezer
Hoover 0914-61 Frigidaire/refrigerator
Hoover 0914-64
Hoover 0916 White Westinghouse/refrigerator
Hoover 0916T
Hoover 0916T-01
Hoover 0920
Admiral 1
Amana 10-2NM Room Air Conditioner
Whirlpool 1005000
Whirlpool 1005200
Whirlpool 1005300
Whirlpool 1005400
Whirlpool 1005500
Amana 1008.000 Mwave - Family Size (60 Hz)
Amana 1009.000 Mwave - Family Size (60 Hz)
Amana 100A-20 Room Air Conditioner
Amana 100A-2M Room Air Conditioner
Amana 100A-2N Room Air Conditioner
Amana 100A-30 Room Air Conditioner
Amana 100A-30H Room Air Conditioner
Amana 100A-356 Room Air Conditioner
Amana 100A-3A Room Air Conditioner
Amana 100A-3HN Room Air Conditioner
Amana 100A-3M Room Air Conditioner
Amana 100A-3N Room Air Conditioner
Amana 100A-3P Room Air Conditioner
Amana 100A-3PH Room Air Conditioner
Amana 100A-3R Room Air Conditioner
Amana 100A-3RH Room Air Conditioner
Amana 100A-556 Room Air Conditioner
Amana 100A-8R Room Air Conditioner
Amana 100B-3A Room Air Conditioner
Amana 100C-20
Amana 100C-20H
Amana 100C-2N Room Air Conditioner
Amana 100C-2N1 Room Air Conditioner
Amana 100C-2P Room Air Conditioner
Amana 100C-2PH Room Air Conditioner
Amana 100C-2R Room Air Conditioner
Amana 100C-2RH Room Air Conditioner
Amana 100C-2RHL Room Air Conditioner
Amana 100C-2RL Room Air Conditioner
Amana 100C-30
Amana 100C-30H
Amana 100C-3N Room Air Conditioner
Amana 100C-3N1 Room Air Conditioner
Amana 100C-3P Room Air Conditioner
Amana 100C-3PH Room Air Conditioner
Amana 100C-3R Room Air Conditioner
Amana 100C-3RH Room Air Conditioner
Amana 100C-3RHL Room Air Conditioner
Amana 100C-3RL Room Air Conditioner
Amana 100C-8P Room Air Conditioner
Amana 100C-8R Room Air Conditioner
Amana 100C-8RH Room Air Conditioner
Amana 100C-8RHL Room Air Conditioner
Amana 100C-8RL Room Air Conditioner
Amana 100D-2HM
Amana 100D-2M
Amana 100D-2MA
Amana 100D-2MB
Amana 100D-356 Room Air Conditioner
Amana 100D-3M
Amana 100D-556 Room Air Conditioner
Amana 100LA-20 Room Air Conditioner
Amana 100LA-2N Room Air Conditioner
Amana 100LC-20
Amana 100LC-2N Room Air Conditioner
Amana 100LC-2P Room Air Conditioner
Amana 100LC-2R Room Air Conditioner
Amana 100LC-2RH Room Air Conditioner
Amana 100LCS-20
Amana 100LCS-2N Room Air Conditioner
Amana 100LCS-2P Room Air Conditioner
Hoover 1010
Amana 1010.000 Mwave - Family Size (60 Hz)
Amana 1011.000 Mwave - Family Size (60 Hz)
Amana 1015.000 Mwave - Family Size (60 Hz)
Amana 1018.000 Mwave - Family Size (60 Hz)
Amana 102.000 Mwave - Family Size (60 Hz)
Amana 102.001 Mwave - Family Size (60 Hz)
Amana 102.002 Mwave - Family Size (60 Hz)
Hoover 1020
Amana 1020.0 Mwave - Family Size (60 Hz)
Amana 1020.000 Mwave - Family Size (60 Hz)
Amana 1021.000 Mwave - Family Size (60 Hz)
Whirlpool 1021B16
  #2 (permalink)
Old 10-28-2011, 06:42 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
It is hard to say based on the info provided, but the place to start is with the drain pump. You need to check to see if it is getting current.
If you want to replace it, go to the parts section of this Site and insert your model number. You will be taken to exploded views of your machine along with the part number. You can use that info to get parts.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water Is Draining As It Fills jbgreer Washer Repair 3 03-29-2011 08:29 PM
Water not draining completely doraj Dishwasher Repair 0 07-31-2010 02:17 PM
Water Not Draining from Tub Dean Ayres Dishwasher Repair 0 03-21-2010 06:19 PM
Water not draining mrmrst Dishwasher Repair 1 04-21-2009 02:48 PM
water not draining image252 Dishwasher Repair 6 02-09-2009 05:09 PM
