My washer is over filling ,not to the piont it over flows but more water than it normaly would use on a load. It used to fill just over the load now it fills to the top of the tub almost. I have replace the water sensor AP3206676 (WH12X10247) - Sensor with no results . the water valves will shut off if i unplug the washer. Thanks Bill
Here is what the service manual says to do
Pressure Sensor Test
If the pressure sensor is not operating correctly, perform the following test: 1. Set the wash cycle to SNEAKERS. This cycle bypasses the load sensing feature and defaults to the minimum water level. 2. Measure the water level from the center hub of the infusor (it should be approximately 2 inches deep in the tub).
3. Set the washer to COMFORTER. This cycle bypasses the load sensing feature and defaults to the maximum water level. 4. Measure the water level from the center hub of the infusor (it should be approximately 11 inches deep in the tub). Note: Before disconnecting the hose from the pressure sensor, be sure the water level is below the bottom of the spin basket. The water level automatically changes on this model depending upon the load of clothes. Check the hose to the pressure switch and clean it out. The inverter controls the water level, so that could also be a problem.
