Discuss
Whirlpool and Whirlpool Made
 in
Washer Repair
On any Whirlpool, Kenmore, Crosley, Roper, or Estate washers, if the drive shaft is changed, does a seal need to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool and Whirlpool Made
  #1 (permalink)
Old 05-11-2009, 08:30 AM
Junior Member
jtowntbo5@yahoo.com is on a distinguished road
Default Whirlpool and Whirlpool Made
Brand: -brand-   Age: Less than 1 year
On any Whirlpool, Kenmore, Crosley, Roper, or Estate washers, if the drive shaft is changed, does a seal need to be changed also? I had a Kenmore that would not turn correctly, and had a good used transmission, and drive shaft, the transmission did nothing to help, so i figured I would try the drive shaft, but i heard it would posssibly need a new seal. I just can't see where a seal would set into on any whirlpool made machine. If anyone needs clarity cause i know its pretty confusing just let me know.
Ads By Google
  #2 (permalink)
Old 05-12-2009, 05:46 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Sorry no one has responded to you earlier. I think people are talking about the tub seal, and making the point that if you remove the tub to replace the brake tube assembly you should replace the tub seal at the time. This is probably good advice, the tub seal is inexpensive and you have already done almost all of the work anyway.
Good luck and let us know how it turns out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Aqua-Pure Filter Made by Whirlpool? ms5150 Refrigerator & Freezer Repair 2 05-22-2010 11:34 PM
Why is the refrigator made this way? walterallenhaxton Refrigerator & Freezer Repair 2 06-08-2009 09:46 AM
no ice being automaticallly made nickk Refrigerator & Freezer Repair 2 01-23-2009 04:33 PM
Kirkland washing machine made by whirlpool jeannine62 Washer Repair 1 09-20-2008 11:21 AM
