| » Washer |
Model Number: LAT4910AAW Brand: Maytag Age: More than 10 years
When the washer has not be used in about 24 hours, clear water will be found in the tub. What part needs to be replaced or is it time to get a new washer?
Related Models |
Sounds like your inlet valves are some grit in them and are leaking because they are not closing completely when they shut down. If it is a small problem, I would let it go, if you want to fix it you will have to replace the valve inlet assembly.
Good luck, and let us know what you decide.
__________________
| Display Modes | |
| help how do you speciffically replace washer timer on Maytag washer | stupid1 | Washer Repair | 5 | 07-04-2009 05:21 PM |
| is this model number washer a direct drive washer | dandjwashington | Washer Repair | 2 | 05-01-2009 07:26 PM |
| Change Washer Lid Switch on Stacked Washer/Dryer | scottcomputers | Washer Repair | 1 | 05-01-2009 10:16 AM |
| maytag washer/dyer combo washer no water | lindavanzandt | Washer Repair | 0 | 11-30-2008 08:35 AM |
