| » will spin, but will not release water |
Model Number: VBXR1090B2WW Brand: Hotpoint Age: 5 - 10 years
my washer will fill up, wash but will not let water out. And then timer will go to rinse cycle and rinse but not let water out.
jfranklin869
Most likely the problem is a bad drain pump or a clog in the drain hose between the tub and the pump. Remove the front panel (# 375 on the cabinet break down diagram ) and disconnect the hose from the drain pump (# 655 on the base break down diagram ). Check the hose and the pump inlet. If this is not the issue then replace the pump. The part number for the new pump AP3193205 Good luck. Gene. |
| Display Modes | |
| drawer release | ciaran | Trash Compactor Repair | 0 | 07-27-2009 05:13 PM |
| will not spin and release water from tub | carla0165 | Washer Repair | 0 | 03-10-2009 10:15 AM |
| Motor humming and water comes but blades don't spin (water pressure problem?) | mtheriault3 | Dishwasher Repair | 4 | 01-11-2009 04:18 PM |
| washer will not spin out all the water in the last spin | myesshowme | Washer Repair | 5 | 10-12-2008 11:35 AM |
| washer will not spin out all the water in the last spin | myesshowme | Washer Repair | 1 | 10-11-2008 05:21 PM |
