How do you remove the knob without breaking it?
In most cases with the knob pressed in it should just unscrew.
Let us know if that does not do the trick.
Originally Posted by: sidfink43 In most cases with the knob pressed in it should just unscrew.
Let us know if that does not do the trick. I ended up hack sawing it off. I could not see how to unscrew it. Thanks, Jeff
Sorry you had trouble, but glad it worked out for you, and thanks for updating us.
