Discuss
Washer knob spins, but doesn't "do" anything?
 in
Washer Repair
The knob spins like it should, and pulls, but it doesn't spin the "dial" on the knob, and when you
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer knob spins, but doesn't "do" anything?
  #1 (permalink)
Old 10-24-2011, 06:19 AM
Junior Member
foladar is on a distinguished road
Default Washer knob spins, but doesn't "do" anything?
Brand: GE   Age: 5 - 10 years
The knob spins like it should, and pulls, but it doesn't spin the "dial" on the knob, and when you pull it, it doesn't start the laundry. Is this just the knob or something else?
Ads By Google
  #2 (permalink)
Old 10-26-2011, 06:07 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Wihtout a model number I can only give you the generic answer which is this. The ridges on the knob on GE models break, and replacing the knob is the cure. It does not cost very much and should fix your problem.
The knob is held on with a u shaped clip that pulls off from behing the knob.
__________________
  #3 (permalink)
Old 10-26-2011, 06:18 PM
Junior Member
Default
The repair man said it was the timer & knob, he reinforced? the timer and replaced knob. Dunno how long it'll work though.
  #4 (permalink)
Old 10-26-2011, 06:35 PM
Senior Expert
APP Volunteer
Default
The timers tend to break away from the bracket that holds them in, that may be what he reinforced.
__________________
  #5 (permalink)
Old 10-26-2011, 06:37 PM
Junior Member
Default
It was like a metal bracket that he placed behind the timer, at least from my view thats what it looked like. Any idea how long that fix is suppose to hold?
  #6 (permalink)
Old 10-27-2011, 04:34 AM
Senior Expert
APP Volunteer
Default
Interesting. I have never seen that bracket break because it is usually the plastic tab that breaks. It should last forever.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch dryer stops, beeps, "Drying" and "End" lights on endyem Dryer Repair 2 10-19-2012 04:46 PM
Neptune MD5500 Washer:Error Codes "do" and "FL" with a triple beep and a buzzer sound neptune123 Washer Repair 1 06-12-2011 04:14 PM
Tub spins fine but does not stabilize, or "center" itself Richard H Washer Repair 1 04-18-2011 11:06 AM
Kenmore 80 Series drops "lock" from drain to spin; spins while draining FalconFour Washer Repair 3 12-20-2010 06:14 AM
oven "moaning" sound then faint "poof" sound; later, large "poof" popped door open samej71 Oven Repair (including Ranges and Cooktops) 2 03-24-2010 07:05 AM
