Pzaul
#1 Posted : Friday, May 8, 2009 8:12:54 PM(UTC)
Pzaul
The timer makes a buzzing noise. I think the timer motor is about to fail. How do I remove the timer? If I can get it out maybe I can replace the timer motor and save a bunch of bucks.
Paul
sidfink43
#2 Posted : Saturday, May 9, 2009 6:04:33 PM(UTC)
sidfink43
Can you post your model number, thanks
Pzaul
#3 Posted : Saturday, May 9, 2009 7:31:04 PM(UTC)
Pzaul
The model number is GLWS1649AS1. I didn't know the number when I posted the question last night.
sidfink43
#4 Posted : Sunday, May 10, 2009 6:26:21 AM(UTC)
sidfink43
Ok, to remove the timer you will take off the back panel, disconnect the timer wire harness, take off the knob and piece under it and you will find two screws holding the timer. Take these out and your timer is removed.
Here is the parts list for your model.
http://manuals.frigidaire.com/p...pdf/Webster/95369161.pdf
I do not see where the timer motor is a separate part, but call the nice folks at Appliance Parts Pro and talk with them. Even if you have to replace the entire timer you will still save beaucoup bucks from a service call.
Good luck and let us know how it works out.
sidfink43
#5 Posted : Sunday, May 10, 2009 6:29:40 AM(UTC)
sidfink43
It may be you have a slightly different type of timer, in which case there is one screw and a locking tab. Either way, you should do fine.
Pzaul
#6 Posted : Sunday, May 10, 2009 8:22:09 AM(UTC)
Pzaul
OK...thanks. But...how do I get the knob off? I can get the center piece off...but nothing else. There has to be some "trick" to getting the knob off and I can't figure it out...help! Thanks Paul
sidfink43
#7 Posted : Sunday, May 10, 2009 9:48:10 AM(UTC)
sidfink43
Ok
See if this helps, and let us know
http://www.applianceaid.com/timerfrigwash.html
Timer removal (Washer Repair)
by ric123 1/29/2013 5:44:54 AM(UTC)
KitchenAid washing machine timer removal (Washer Repair)
by AndrewK 5/17/2012 2:34:33 PM(UTC)
washer timer removal (Washer Repair)
by jadabdo 6/27/2011 3:58:56 PM(UTC)
defrost timer removal (Refrigerator & Freezer Repair)
by boschoff 6/1/2011 10:07:47 AM(UTC)
Kitchenaid Washer Timer Removal (Washer Repair)
by bdecosmo 6/24/2010 6:17:32 AM(UTC)
Knob & Dial Timer Removal on Sears Washer (Washer Repair)
by RFaust 1/5/2010 8:05:22 AM(UTC)
