| » Frigidaire front loader will not spin |
Model Number: FWT647GHS1 Brand: Frigidaire Age: 5 - 10 years
Frigidaire front loader will not spin, but it will go through all other cycles and pumps out water.
Check the door lock switch.
__________________
You can Repair your Appliance & we can help with our Appliance Repair Forum and Appliance Repair Blog. |
My Frigidaire Washer Does The Same As Lone-rider's Does. It Will Go Through The Fill Cycle, Wash Cycle But Drum Doesn't Turn. Drain Cycle, Etc. Won't Spin At All. Belt Is Good. Motor Doesn't Smell Burn't. When I Said I Checked The Door Latch I Opened The Door And Set The Washer To The Fill Cycle And Nothing Happened. I Then Shut The Fill Cycle Off. I Closed The Door And Turned The Fill Cycle On Again And This Time The Washer Started To Fill. That Is Telling Me That The Door Latch Must Be Working. I Don't Have A Wiring Diagram For This To See If The Latch Is Tied In Some Other Way. I Would Appreciate Any Other Advice. Thanks.
Frigidair has a fine chain diagram for this failure in the service manual underneath
It includes checking the soap dispenser magnetic switch, the timer contacts and the door latch. Door latch must lock before spin is enabled.
__________________
| Display Modes | |
| Kenmore front loader washer works fine but does not spin | busted | Washer Repair | 7 | 11-01-2008 01:11 PM |
| front loader washer | Donald Belanger | Washer Repair | 4 | 12-07-2007 06:53 PM |
| Frigidaire Front Load Washer Won't Spin | bbemis | Washer Repair | 2 | 11-28-2007 08:46 AM |
| spin cycle on frigidaire front load | Mikki | Washer Repair | 2 | 10-08-2007 05:15 PM |
| front loader not draining | distress | Washer Repair | 1 | 09-14-2007 03:24 AM |
