Hello, I have a Maytag washing machine Mod LAT7300AAW that overfills enough to flood out the basement. I pumped out the water, checked the fill valves and they open and shut off as they should. The Pump works well. I drained the machine using the pump on the spin cycle, then started a new load using the "small load" setting. It filled all the way to the top. Moved the selector to spin and it pumped right out. The kicker is that Maytag has discontinued this switch. I hate to have to scrap the machine for a 20 or 30 dollar switch. Any suggestions? Thank you, Bruce
