Discuss
Washer timer motor in timer assembly
 in
Washer Repair
My timer stopped working on my maytag. it works fine if you manually turn the dial. I removed the timer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer timer motor in timer assembly
  #1 (permalink)
Old 10-23-2011, 05:39 PM
Junior Member
marinekilz is on a distinguished road
Default Washer timer motor in timer assembly
Model Number: 22001026, 6-2083380, ap4026633   Brand: Maytag   Age: More than 10 years
My timer stopped working on my maytag. it works fine if you manually turn the dial. I removed the timer assembly. with some research I found this timer to have afew parts number that refer to it. They are 22001026, 6-2083380, and AP4026633. Now I can apon inspection I found there is a motor on the assembly. I removed and tested this motor, the motor no longer works. The markings on the motor are m001 3w s 115 vac 60 hz. I would like to just replace that motor. Does anyone know where to buy one instead of me shelling out +$100 for a new timer assembly complete?? Thanks for your help in advance
I tried to add picture, but they didn't come out in the thread.
Related Models
Frigidaire 220035201066 INDOOR/OUTDOOR UNIT
Hoover 2201
Hoover 2204
Roper 2204*0A Ranges, Electric*
Roper 2204*1A Ranges, Electric*
Roper 2204*2A Ranges, Electric*
Roper 2204W0A Ranges, Electric*
Roper 2204W1A Ranges, Electric*
Roper 2204W2A Ranges, Electric*
Amana 2208.100 COMMERCIAL MICROWAVES
Amana 2208.101 COMMERCIAL MICROWAVES
Amana 2208.A COMMERCIAL MICROWAVES
Hoover 2210
Amana 2210.000 MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air 22112 SURFACE UNIT- DDRAFT ELE
Jenn-Air 22113 SURFACE UNIT- DDRAFT ELE
Jenn-Air 22114 SURFACE UNIT- DDRAFT ELE
Jenn-Air 22115 SURFACE UNIT- DDRAFT ELE
Jenn-Air 22116 SURFACE UNIT- DDRAFT ELE
Roper 2214*0A Ranges, Electric*
Roper 2214*1A Ranges, Electric*
Roper 2214*2A Ranges, Electric*
Roper 2214W0A Ranges, Electric*
Roper 2214W1A Ranges, Electric*
Roper 2214W2A Ranges, Electric*
Amana 2215S ROOM AIR CONDITIONER
Roper 2216*00 Ranges, Electric*
Roper 2216*10 Ranges, Electric*
Roper 2216*20 Ranges, Electric*
Roper 2216W00 Ranges, Electric*
Roper 2216W10 Ranges, Electric*
Roper 2216W20 Ranges, Electric*
Frigidaire 2221 GAS RANGE
Roper 2224*0A Ranges, Electric*
Roper 2224*1A Ranges, Electric*
Roper 2224W0A Ranges, Electric*
Roper 2224W1A Ranges, Electric*
Jenn-Air 22305 SURFACE UNIT- DDRAFT ELE
Frigidaire 2231 GAS RANGE
Roper 2233*0A Ranges, Electric*
Roper 2233*1A Ranges, Electric*
Roper 2233W0A Ranges, Electric*
Roper 2233Z1A Ranges, Electric*
Roper 2234*0A Ranges, Electric*
Roper 2234*1A Ranges, Electric*
Roper 2234*2A Ranges, Electric*
Amana 2234.000 MWAVE - FAMILY SIZE (60 HZ)
Roper 2234W0A Ranges, Electric*
Roper 2234W1A Ranges, Electric*
Roper 2234W2A Ranges, Electric*
Roper 2236*00 Ranges, Electric*
Roper 2236*10 Ranges, Electric*
Roper 2236*20 Ranges, Electric*
Amana 2236.100 COMMERCIAL MICROWAVES
Amana 2236.101 COMMERCIAL MICROWAVES
Roper 2236W00 Ranges, Electric*
Roper 2236W10 Ranges, Electric*
Roper 2236W20 Ranges, Electric*
Amana 2237.A MWAVE - FAMILY SIZE (60 HZ)
Amana 2238.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2238.001 MWAVE - FAMILY SIZE (60 HZ)
General Electric 22388L0 Electric range
General Electric 22388W0 Electric range
Amana 2239.A MWAVE - FAMILY SIZE (60 HZ)
Amana 2240.000 MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air 22401 SURFACE UNIT- DDRAFT ELE
Jenn-Air 22402 SURF CONT PANEL UNIT- DDFT ELE
Jenn-Air 22403 SURF CONT PANEL UNIT- DDFT ELE
Jenn-Air 22404 SURF CONT PANEL UNIT- DDFT ELE
Frigidaire 2241 GAS RANGE
Roper 2244*0A Ranges, Electric*
Roper 2244*1A Ranges, Electric*
Roper 2244*2A Ranges, Electric*
Roper 2244W0A Ranges, Electric*
Roper 2244W1A Ranges, Electric*
Roper 2244W2A Ranges, Electric*
Jenn-Air 2250ENC WALLOVEN- STD ELE
Jenn-Air 2250ENS JENN-AIR COOKING
Amana 2254.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2254.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2254.A MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air 2255 WALLOVEN- STD ELE
Jenn-Air 2255ENC WALLOVEN- STD ELE
Jenn-Air 2255ENS JENN-AIR COOKING
Hoover 2260
Roper 2265*0A Ranges, Electric*
Roper 2265W0A Ranges, Electric*
Hoover 2266
Amana 2274.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2274.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2274.A MWAVE - FAMILY SIZE (60 HZ)
Roper 2275*0A Ranges, Electric*
Roper 2275W0A Ranges, Electric*
Roper 2276*0A Ranges, Electric*
Roper 2276*1A Ranges, Electric*
Amana 2276.A MWAVE - FAMILY SIZE (60 HZ)
Roper 2276W0A Ranges, Electric*
Roper 2276W1A Ranges, Electric*
Jenn-Air 2280EEL WALLOVEN- STD ELE
Frigidaire 2281 GAS RANGE
Jenn-Air 2281EEL WALLOVEN- STD ELE
Magic Chef 22FA-2KLW RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FA-2KW WALLOVEN-STD DBL OVEN GAS
Magic Chef 22FA-6CKLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22FA-6KLX RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FA-6KLX-6F RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FA-6KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22FK-2KLW RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FK-2KW WALLOVEN-STD DBL OVEN GAS
Magic Chef 22FK-6KLX RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FK-6KLX-6F RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FK-6KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22FN-2KLW RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FN-2KW WALLOVEN-STD DBL OVEN GAS
Magic Chef 22FN-6CKLXV8 MAGIC CHEF COOKING
Magic Chef 22FN-6KLX RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FN-6KLX-6F RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FN-6KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22FY-2KLW RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FY-2KW WALLOVEN-STD DBL OVEN GAS
  #2 (permalink)
Old 10-25-2011, 06:55 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Some models have a separate parts listing for the timer motor, and for the most part timer motors are all the same.
I can only suggest you look around the parts diagrams on this site for washers or call APP and ask them if they have a timer motor, and get the part number and look at it online. You may find one that will match up.
__________________
  #3 (permalink)
Old 10-31-2011, 06:14 PM
Junior Member
Default
for some reason I can not find the same timer or matching part number anywhere. or just the timer motor anywhere. Does anyone know the difference between a maytag 6-2083370 and a 6-2083380. for some reason I can find alot of the 6-2083370 but can't find the one exactly for my washer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Timer or Timer Motor? lstuewe Washer Repair 1 09-19-2011 02:38 AM
Washer spinning indefinitely. Replaced belt, timer and lubed motor slides. juandiablo Washer Repair 1 07-17-2011 05:20 PM
Maytag washer, timer good till rinse-no spin,drain orstop/timer keeps clicking freely partsparts Washer Repair 3 08-23-2010 01:50 AM
Bad timer/timer motor kertz3 Washer Repair 0 05-26-2010 02:22 PM
Does the washer timer energize the starter coil of the motor? oreospike Washer Repair 1 01-05-2009 07:06 AM
