| » Washer Won't Spin |
Model Number: Ral5144BWO Brand: Roper Age: More than 10 years
This washer has been great - for many years absolutely no problems. Starting yesterday it would not spin. It agitates, rinses, drains. It does everything normally except no spin. When it gets to the spin cycle it sounds normal - no unusual noises. Actually sounds like it is spinning but when you open it up you can see the drum has not moved. Bad lid switch or motor coupling maybe or motor bad altogether? Any ideas on what the problem is? Thanks!
Related Models |
Took machine apart and discovered a borken piece called the driver,brake came (part 64194). Its part of the brake and drive tube. Went to the shop and found a replacement part for it and the machine now appears to work just fine.
We are glad you were able to fix it. Good job!
__________________
Professional appliance repair in Orange County, California. |
| Display Modes | |
| Whirlpool washer won't spin on rinse cycle or high spin | bry21317 | Washer Repair | 4 | 08-19-2009 06:32 PM |
| Frigidare front load washer will not spin durning final spin cyle | binky8992 | Washer Repair | 2 | 08-19-2009 06:29 PM |
| Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) | cowboys#1 | Washer Repair | 7 | 03-05-2009 04:26 PM |
| washer will not drain for 1st spin cycle. Does finish with spin dry | tec6422 | Washer Repair | 1 | 01-23-2009 07:44 AM |
| whirlpool washer won't spin manually or spin | boniam | Washer Repair | 15 | 06-29-2008 07:19 AM |
