Discuss
Maytag Stack Lid Switch Repair
 in
Washer Repair
THE LID SWITCH BROKE ON MY WASHER. HOW DO I GET TO IT TO REPLACE IT? ALSO WHAT SCREWS I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Stack Lid Switch Repair
  #1 (permalink)
Old 12-09-2007, 10:25 AM
rbooher2003 rbooher2003 is offline
Junior Member
rbooher2003 is on a distinguished road
Post Maytag Stack Lid Switch Repair
Model Number: LSE1000 SERIES Q0   Brand: Maytag   Age: More than 10 years
ALSO WHAT SCREWS I CAN SEE ON THE WASHER ARE VERY RUSTY, ANY IDEAS BESIDES WD40 ON GETTING THEM OUT?
I also have a washer from an LSE1000 Series 1 that works. Will it work with the controller on the series 10?
Thanks,
Rich
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-11-2008, 09:51 AM
milli milli is offline
Junior Member
milli is on a distinguished road
Default Maytag Stack Lid Switch Repair
Rich, Don't know if you have resolved this problem or not, but I have the same issue. I know the front comes off this model, but I think the slant panel has to come off first. My lid problem only began after a 3 month summer vacation during which I kept my a/c off and my basement got so damp nearly everything was mildewed or rusted. Anyway, I never shut my lid all the way when I am finished washing, in order to keep less wear and tear on the switch. It will finally engage (I get an "L" prompt on the panel) if I open and close the lid enough times, sometimes, having to turn off and on as many as 15 times before it will work. I know that's not a good workaround, but from what I could see when once I put the setting on Pause and opened the lid while the tub was filing, I think the water input hose needs cleaning because it sprays all over the inside and edges of the tub. It usually works well, once I can get it going. I think the lid sensing mechanism has rusted from last summer's humidity and now that the spray is going everywhere, that's contributing to the problem. When I can save enough money, I'll hire a repairman. Good luck in troubleshooting your washer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
infinite switch wiring change from 6 wires to 5 wire switch wiedemanndds Oven Repair (including Ranges and Cooktops) 3 12-06-2007 01:45 PM
Infinite switch and fan switch johnro24 Oven Repair (including Ranges and Cooktops) 0 12-05-2007 10:01 PM
Maytag Washer Inlet valve - water level switch reisman Washer Repair 0 10-23-2007 09:36 PM
maytag switch removal jerman Washer Repair 1 10-13-2007 09:11 PM
freezer light switch repair paynerc Refrigerator & Freezer Repair 5 09-02-2007 10:19 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
