I have a coin-op washer that does not spin dry the clothes in final spin. i have put on new belts and this did not help. What should I try next? I noticed that the timer may be off. The timer starts of at 30 minutes. It washes for about 15-18 minutes then it spins for about 5 or so then when it fills up to rinse, it only rinses for 1 minute then it goes into spin and there is only 4 minutes left on the spin cycle. I feel that this isn't long enough for rinsing or spinning. So is it the timer or is the motor to weak to run it accordingly? Is there any thing else that could be causing the problem? Any suggestions or recommendations would greatly be appreciated? Thank you Mary K.
I am not experienced on coin ops, but this does sound like a timer problem.
