Discuss
Moises
 in
Washer Repair
Washer will do everything up until the Drain/Rinse/Spin Cycle. It stops and finish the timer run with water still in
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Moises
  #1 (permalink)
Old 10-21-2011, 09:48 AM
Junior Member
2501329 is on a distinguished road
Smile Moises
Model Number: VBXR1070WOWW   Brand: Hotpoint   Age: 1 - 5 years
Washer will do everything up until the Drain/Rinse/Spin Cycle. It stops and finish the timer run with water still in it.
Related Models
General Electric VBXR1090B0CC Washer
General Electric VBXR1090B0WW Washer
General Electric VBXR1090B2CC Washer
General Electric VBXR1090B2WW Washer
General Electric VBXR1090B3CC Washer
General Electric VBXR1090B3WW Washer
General Electric VBXR1090B4CC Washer
General Electric VBXR1090B4WW Washer
General Electric VBXR1090D0CC Washer
General Electric VBXR1090D0WW Washer
General Electric VBXR1090D1WW Washer
General Electric VBXR1090D2CC Washer
General Electric VBXR1090D2WW Washer
General Electric VBXR1090D3WW Washer
General Electric VBXR1090D4WW Washer
General Electric VBXR1090D5CC Washer
General Electric VBXR1090D5WW Washer
General Electric VBXR1090D6WW Washer
General Electric VBXR1090D7WW Washer
General Electric VBXR1090D8CC Washer
General Electric VBXR1090D8WW Washer
General Electric VBXR1090D9WW Washer
General Electric VBXR1090DACC Washer
General Electric VBXR1090DAWW Washer
General Electric VBXR1090DBCC Washer
General Electric VBXR1090DBWW Washer
General Electric VBXR1090DDCC Washer
General Electric VBXR1090DDWW Washer
General Electric VBXR2070T2AB Washer
General Electric VBXR2070T2WB Washer
General Electric VBXR2070T3AB Washer
General Electric VBXR2070T3WB Washer
General Electric VBXR2070T5AB Washer
General Electric VBXR2070T5WB Washer
General Electric VBXR2070T6AB Washer
General Electric VBXR2070T6WB Washer
General Electric VBXR2070T8AB Washer
General Electric VBXR2070T8WB Washer
General Electric VBXR2070TAAB Washer
General Electric VBXR2070TAWB Washer
General Electric VBXR2070V0AA Washer
General Electric VBXR2070V0WW Washer
General Electric VBXR2070V1AA Washer
General Electric VBXR2070V1WW Washer
Thermador VC-500
Gaggenau VC112-602
Gaggenau VC113-602
Gaggenau VC114-602
Gaggenau VC116-602
Gaggenau VC230-612
Gaggenau VC343-602
Gaggenau VC345-602
Gaggenau VC355-602
Thermador VCH-2 CONTROL HOUSING
Thermador VCH-3 RANGE HOOD
Thermador VCH-6 CONTROL HOUSING
Thermador VCH-6A CONTROL HOUSING
Thermador VCH-7 CONTROL HOUSING
Thermador VCH-7A CONTROL HOUSING
Thermador VCH-8 CONTROL HOUSING
Thermador VCH-9 CONTROL HOUSING
Amana VCH3 ELE CARTRIDGE
Thermador VCH36
Amana VCH4 ELE CARTRIDGE
Thermador VCH54
Thermador VCK-1 VENTILATOR
Thermador VCK-1A RANGE HOOD
Thermador VCK-300
Bosch VD030-000
Bosch VD030-010
Bosch VD030-099
Bosch VD040-000
Bosch VD040-010
Bosch VD040-099
Bosch VD050-010
Gaggenau VE112-612
Frigidaire VE21AW5 Tap(v1) / Electric Range
Amana VE3013 WASHER-TOP LOADING
Frigidaire VE30AW5 Tap(v1) / Electric Range
Frigidaire VE30BW4 Tap(v1) / Electric Range
Frigidaire VE30CW4 Tap(v1) / Electric Range
Gaggenau VE313-613
Amana VE5013 WASHER-TOP LOADING
Amana VEND-10.000 COMMERCIAL MICROWAVES
Amana VEND-10.A COMMERCIAL MICROWAVES
Amana VEND-10.B COMMERCIAL MICROWAVES
Amana VEND-10.C COMMERCIAL MICROWAVES
Amana VEND-10.F COMMERCIAL MICROWAVES
Amana VEND-10.G COMMERCIAL MICROWAVES
Amana VEND-10.H COMMERCIAL MICROWAVES
Amana VEND-10.J COMMERCIAL MICROWAVES
Amana VEND-7.003 COMMERCIAL MICROWAVES
Amana VEND-7.004 COMMERCIAL MICROWAVES
Amana VEND-7.005 COMMERCIAL MICROWAVES
Amana VEND-7.A COMMERCIAL MICROWAVES
Amana VEND-7.B COMMERCIAL MICROWAVES
Amana VEND-7D.001 COMMERCIAL MICROWAVES
Amana VEND-7D.A COMMERCIAL MICROWAVES
Amana VEND10 COMMERCIAL MICROWAVES
Amana VEND11 COMMERCIAL MICROWAVES
Amana VEND11B COMMERCIAL MICROWAVES
Hoover VER1360AGH RANGE- F/S STD ELE
Gaggenau VF112-610
Gaggenau VF230-610
Gaggenau VF332-610
Frigidaire VG21AW3 Tap(v1) / Gas Range
Frigidaire VG21AW3-23 Tap(v2) / Gas Range
Gaggenau VG223-812
Gaggenau VG230-811
Gaggenau VG231-211CA
Gaggenau VG232-212CA
Amana VG3019 WASHER-TOP LOADING
Frigidaire VG30AW3 Tap(v1) / Gas Range
Frigidaire VG30AW3-23 Tap(v2) / Gas Range
Frigidaire VG30BW2 Tap(v1) / Gas Range
Frigidaire VG30BW2-23 Tap(v2) / Gas Range
Frigidaire VG30CW2 Tap(v1) / Gas Range
Frigidaire VG30CW2-23 Tap(v2) / Gas Range
Gaggenau VG330-811
  #2 (permalink)
Old 10-22-2011, 07:45 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
You have an electric pump in this model, and it operates independently of the transmission. This suggests an electrical problem, probably with the control unit.
__________________
  #3 (permalink)
Old 10-23-2011, 08:38 AM
Junior Member
Default
Quote:
Thanks for replying, I found the problem... The Pump was disabled by a clogged inlet With Shreded pieces of a cushion filling and a baby Sock(Believe it or not). I noticed that the washer wasn't draining by gravity.Seems like the cushion disintegrated and fluffed up and fell over the edge of the inner tub and was sucked into the pump completedly jamming it. I noticed the motor humming but not turning and getting HOT. Removed the blockage and"Wallah" It started working. I take it that The sensor of water level detected water in the Drain/Spin Cycle and refused to reverse the Motor.. Does that makes sense to you? Thanks again :-)
  #4 (permalink)
Old 10-23-2011, 11:07 AM
Senior Expert
APP Volunteer
Default
Sounds good
Glad you got it fixed and thanks for updating us.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
