Discuss
water leaks in sppin cycle from ceter of tub
 in
Washer Repair
washer leaks from under center of tub in spin cycle what all seals wuold need to be changed to stop
Appliance Repair Forum > Appliance Repair Help > Washer Repair » water leaks in sppin cycle from ceter of tub
  #1 (permalink)
Old 05-06-2009, 08:52 AM
Junior Member
dodgezilla is on a distinguished road
Default water leaks in sppin cycle from ceter of tub
Model Number: lw4303w   Brand: Amana   Age: More than 10 years
washer leaks from under center of tub in spin cycle what all seals wuold need to be changed to stop leak or would a drive bell and seal kit fix it or is there more seals under this that would also need changed.
Ads By Google
Related Models
Amana LW4303W Washer - Top Loading
Amana LW4603L Washer - Top Loading
Amana LW4603W Washer - Top Loading
Amana LW6001W2 Washer - Top Loading
Amana LW6101WB Washer - Top Loading
Amana LW6111LB Washer - Top Loading
Amana LW6111WB Washer - Top Loading
Amana LW6123LM Washer - Top Loading
Amana LW6123WM Washer - Top Loading
Amana LW6143LM Washer - Top Loading
Amana LW6143WM Washer - Top Loading
Amana LW6153LB Washer - Top Loading
Amana LW6153LM Washer - Top Loading
Amana LW6153WB Washer - Top Loading
Amana LW6153WM Washer - Top Loading
Amana LW6163LM Washer - Top Loading
Amana LW6163WM Washer - Top Loading
Amana LW6501W2 Washer - Top Loading
Amana LW6501W2B Washer - Top Loading
Amana LW6601W2 Washer - Top Loading
Amana LW6661W2 Washer - Top Loading
Amana LW7503L2 Washer - Top Loading
Amana LW7503W2 Washer - Top Loading
Amana LW7563W2 Washer - Top Loading
Amana LW8201L2 Washer - Top Loading
Amana LW8201W2 Washer - Top Loading
Amana LW8203L2 Washer - Top Loading
Amana LW8203W Washer - Top Loading
Amana LW8203W2 Washer - Top Loading
Amana LW8203W2B Washer - Top Loading
Amana LW8252L2 Washer - Top Loading
Amana LW8252W2 Washer - Top Loading
Amana LW8253W Washer - Top Loading
Amana LW8263W2 Washer - Top Loading
Amana LW8303L2 Washer - Top Loading
Amana LW8303W2 Washer - Top Loading
  #2 (permalink)
Old 05-06-2009, 02:31 PM
Senior Expert
APP Volunteer
Drags1998 is on a distinguished road
Default
Not only do you need ALL seals, you will also need to replace the spin bearings.(water gets into them and they fail within a Month!!!!! Othet tech's may disagree with Me but I say Trash it and get another one!!!
__________________
  #3 (permalink)
Old 05-06-2009, 02:36 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Drags is exactly correct on this. You do not want to spend the time and effort required for this repair on a machine this old.
Sorry we could not have better news.
__________________
  #4 (permalink)
Old 05-10-2009, 10:16 AM
Junior Member
Default washer leaking
thank you thats what i needed to know wether or not worth fixing
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
The water dispenser leaks continually, had to cut the water off to stop it Willie Jones Refrigerator & Freezer Repair 1 07-12-2009 06:28 PM
ge dishwasher leaks after cycle hkocis Dishwasher Repair 0 11-23-2008 09:37 AM
leaks a LOT on spin cycle ldmoff123 Washer Repair 12 09-13-2008 07:58 AM
Washer Leaks Water Into Tub After Cycle zinnco Washer Repair 1 09-11-2008 04:51 PM
Leaks during rinse cycle GRD7650 Washer Repair 0 04-04-2008 06:36 PM
