Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   water leaks in sppin cycle from ceter of tub (http://forum.appliancepartspros.com/washer-repair/32701-water-leaks-sppin-cycle-ceter-tub.html)
dodgezilla 05-06-2009 08:52 AM
washer leaks from under center of tub in spin cycle what all seals wuold need to be changed to stop leak or would a drive bell and seal kit fix it or is there more seals under this that would also need changed.
Drags1998 05-06-2009 02:31 PM
Not only do you need ALL seals, you will also need to replace the spin bearings.(water gets into them and they fail within a Month!!!!! Othet tech's may disagree with Me but I say Trash it and get another one!!!
sidfink43 05-06-2009 02:36 PM
Drags is exactly correct on this. You do not want to spend the time and effort required for this repair on a machine this old.
Sorry we could not have better news.
dodgezilla 05-10-2009 10:16 AM
washer leaking
thank you thats what i needed to know wether or not worth fixing
