Discuss
Replacing direct drive washer brake shoes
 in
Washer Repair
Then put oil on the pad and work some silicone grease in the roller. 1. Will any 2/1 household oil
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Replacing direct drive washer brake shoes
  #31 (permalink)
Old 02-08-2012, 11:03 AM
Junior Member
Clubbuilder is on a distinguished road
Default Lubricant Specification
1. Will any 2/1 household oil due for the pad?
2. Is putting oil on the brake shoes necessary?
3. Last, will any silicone grease work on the roller. I mean, I am buying the brake shoes through your website but buying this lubricant: WHIRLPOOL Lubricant, part number: AP3131935 that almost cost as much as the brake itself seems like a waste of money.
Ads By Google
  #32 (permalink)
Old 03-07-2012, 02:27 PM
Member
Markram is on a distinguished road
Default
Quote:
Originally Posted by spacecase View Post
Do u happen to know where I can get a diagramed manual for a Kenmore 80 series
You can usually obtain a technician manual of most washers by looking beneath the control panel assembly. For front loaders, it is usually behind the lower toe panel or sometimes on the inner side wall.
You can also order most tech manuals from Sears.
  #33 (permalink)
Old 04-24-2012, 02:56 PM
Junior Member
Ed209 is on a distinguished road
Default
Hello. I pulled my motor from the transmission and tried to rotate the transmission using the coupler. The shaft just keeps turning. It doesn't engage the basket at all.
I replaced the coupler but it broke during the first load.
When I first tried to rotate the shaft clockwise,it was really hard to turn. I tried to turn the basket by hand and it moved but it too was hard to turn. After I turned the basket by hand,the shaft doesn't catch on anything.
Is this a brake shoes problem?
  #34 (permalink)
Old 04-24-2012, 04:03 PM
Junior Member
Default
An update to my question:
I pulled the transmission out to look at the brake pads and put a little oil on the pads. They don't seem to be very tight,they turn easily in the housing.
Can I rule out the brake pads as the reason for the coupler breaking?
  #35 (permalink)
Old 10-18-2012, 04:16 PM
Junior Member
mtnbiker3000 is on a distinguished road
Default
Bump... These are great questions I am really interested in the answers...
  #36 (permalink)
Old 03-06-2013, 06:15 AM
Junior Member
Nitro itch is on a distinguished road
Default Direct drive motor draws 12 amps during agitation !!
Regardless of which motor and transmission I swap into this machine ( 2 different good used transmissions and 3 different good used motors ) this 10yr WP will draw 12 ton13 amps when agitating with large load. Tub and basket clean and nothing jamming them, basket tube to shaft clean and lubed, and waterpump clear.
During spin cycle motor draws 8 to 9 amps with same load of clothes.
Also, if these motors are thermally protected, at what temp should it trip?
Each of these motors get too hot to touch, yet still keep running at 12 amps. There is no smell of electrical motor failure. And this process has been done outside with cabinet removed and ambient temp is 65 degrees.
Do these motors have a "service factor" amp draw? If so its not stated on motor along with their rating.
Perhaps I'm not getting a good connection to motor during agitation?? If so I m thinking of bypassing timer and wire harnest to motor switch,,,,but which wire combinations should I send a direct power source to for not hi and lo agitations?
Any help or thoughts is appreciated.
  #37 (permalink)
Old 03-06-2013, 08:13 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
2-speed or 3-speed motor?
  #38 (permalink)
Old 03-06-2013, 01:03 PM
Junior Member
Default
2speed.....it draws only 8 to 9amps when in low agitation.
  #39 (permalink)
Old 03-06-2013, 03:11 PM
Expert
APP Volunteer
Default
For high speed on a 2-speed motor connect hot to motor blue wire and yellow wire. Connect neutral to motor white and capacitor. Remove red wire coming from timer from capacitor and connect there (to the capacitor). For low speed, hot to motor orange and yellow.
I don't know the trip temp rating for the thermal overload but the motor is rated for max ambient surrounding air temp of 40°C (104°F) and winding insulation rating of 130°C (266°F). The thermal switch is mounted on the frame right next to the motor switch.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/washer-repair/3265-replacing-direct-drive-washer-brake-shoes.html
Posted By For Type Date
Part Details - WHIRLPOOL Spin Tube Thrust Washer, part number: AP2905330 This thread Refback 09-12-2011 04:50 PM
WHIRLPOOL Neutral Drain Transmission, AP3096209 | AppliancePartsPros.com This thread Refback 09-12-2011 07:20 AM
Part Details - WHIRLPOOL Motor - Drive, part number: AP2907254 This thread Refback 09-12-2011 03:39 AM
WHIRLPOOL Spin Tube Thrust Washer, AP2905330 | AppliancePartsPros.com This thread Refback 09-09-2011 08:27 PM
WHIRLPOOL Motor - Drive, AP2907254 | AppliancePartsPros.com This thread Refback 09-06-2011 10:34 AM
Part Details - WHIRLPOOL Agitator Dogs, part number: AP3119063 This thread Refback 09-05-2011 05:26 PM
Part Details - WHIRLPOOL Gear and Pinon, part number: AP3094405 This thread Refback 09-03-2011 04:42 PM
WHIRLPOOL 285938 Timer, AP3605418 | AppliancePartsPros.com This thread Refback 08-31-2011 05:46 PM
WHIRLPOOL Neutral Drain Transmission, AP3096209 | AppliancePartsPros.com This thread Refback 08-31-2011 09:14 AM
WHIRLPOOL 3360629 Neutral Drain Transmission, AP3096209 | AppliancePartsPros.com This thread Refback 08-31-2011 06:05 AM
WHIRLPOOL Switch - Sen, AP4501024 | AppliancePartsPros.com This thread Refback 08-30-2011 05:02 PM
WHIRLPOOL 285785 Clutch Assembly, AP3094537 | AppliancePartsPros.com This thread Refback 08-29-2011 03:30 PM
Part Details - WHIRLPOOL Clutch Assembly, part number: AP3094537 This thread Refback 08-21-2011 08:09 AM
WHIRLPOOL 285792 Basket Drive and Brake Assembly, AP3094539 | AppliancePartsPros.com This thread Refback 08-21-2011 02:13 AM
WHIRLPOOL 3360629 Neutral Drain Transmission, AP3096209 | AppliancePartsPros.com This thread Refback 08-21-2011 02:05 AM
WHIRLPOOL 389248 Drive Motor - 2 Speed, AP2905451 | AppliancePartsPros.com This thread Refback 08-20-2011 08:09 AM
Part Details - WHIRLPOOL Clutch Assembly, part number: AP3094537 This thread Refback 08-17-2011 04:23 PM
WHIRLPOOL Automatic Washer (direct Drive) - Whirlpool Repair Manuals, AP3073574 | AppliancePartsPros.com This thread Refback 08-14-2011 01:56 PM
WHIRLPOOL Basket Drive and Brake Assembly, AP3094539 | AppliancePartsPros.com This thread Refback 08-14-2011 09:26 AM
WHIRLPOOL Whirlpool Direct Drive Washer Motor Coupling, AP3963893 | AppliancePartsPros.com This thread Refback 08-08-2011 08:00 AM
WHIRLPOOL 285362 Gear & Pinon, AP3094405 | AppliancePartsPros.com This thread Refback 08-06-2011 11:56 PM
WHIRLPOOL 388253 Neutral Drain Kit, AP3018165 | AppliancePartsPros.com This thread Refback 08-05-2011 06:26 PM
WHIRLPOOL 285753A Whirlpool Direct Drive Washer Motor Coupling, AP3963893 | AppliancePartsPros.com This thread Refback 08-01-2011 03:17 PM
WHIRLPOOL 285438 Brake Shoe, AP3094432 | AppliancePartsPros.com This thread Refback 07-18-2011 09:38 AM
WHIRLPOOL Whirlpool Direct Drive Washer Pump, AP2907492 | AppliancePartsPros.com This thread Refback 07-16-2011 03:33 PM
WHIRLPOOL W10292584 Switch - Sen, AP4501024 | AppliancePartsPros.com This thread Refback 07-10-2011 02:20 PM
WHIRLPOOL 285792 Basket Drive and Brake Assembly, AP3094539 | AppliancePartsPros.com This thread Refback 07-07-2011 05:58 PM
Part Details - WHIRLPOOL Agitator Dogs, part number: AP3119063 This thread Refback 07-01-2011 01:31 PM
WHIRLPOOL Agitator Dogs, AP3119063 | AppliancePartsPros.com This thread Refback 06-30-2011 06:38 PM
WHIRLPOOL Automatic Washer (direct Drive) - Whirlpool Repair Manuals, AP3073574 | AppliancePartsPros.com This thread Refback 06-24-2011 03:35 PM
WHIRLPOOL 285938 Timer, AP3605418 | AppliancePartsPros.com This thread Refback 06-23-2011 02:09 PM
WHIRLPOOL Neutral Drain Transmission, AP3096209 | AppliancePartsPros.com This thread Refback 06-23-2011 11:35 AM
Part Details - WHIRLPOOL Gear & Pinon, part number: AP3094405 This thread Refback 06-21-2011 07:53 AM
Part Details - WHIRLPOOL SWITCH-SEN, part number: AP4501024 This thread Refback 06-20-2011 05:43 PM
WHIRLPOOL 285785 Clutch assembly, AP3094537 | AppliancePartsPros.com This thread Refback 06-18-2011 10:33 AM
WHIRLPOOL 3360629 Neutral drain transmission, AP3096209 | AppliancePartsPros.com This thread Refback 06-16-2011 06:08 PM
WHIRLPOOL SWITCH-SEN, AP4501024 | AppliancePartsPros.com This thread Refback 06-15-2011 02:42 PM
WHIRLPOOL Whirlpool direct drive washer motor coupling, AP3963893 | AppliancePartsPros.com This thread Refback 06-15-2011 05:29 AM
WHIRLPOOL Whirlpool direct drive washer pump, AP2907492 | AppliancePartsPros.com This thread Refback 06-09-2011 01:29 AM
Part Details - WHIRLPOOL Basket drive and brake assembly, part number: AP3094539 This thread Refback 06-06-2011 09:39 PM
Part Details - WHIRLPOOL Whirlpool direct drive washer motor coupling, part number: AP3963893 This thread Refback 06-05-2011 02:07 PM
WHIRLPOOL Drive motor - 2 speed, AP2905451 | AppliancePartsPros.com This thread Refback 06-04-2011 06:00 PM
Part Details - WHIRLPOOL Brake shoe, part number: AP3094432 This thread Refback 06-04-2011 09:04 AM
Part Details - WHIRLPOOL Brake shoe, part number: AP3094432 This thread Refback 06-03-2011 09:38 PM
WHIRLPOOL Brake shoe, AP3094432 | AppliancePartsPros.com This thread Refback 06-03-2011 05:46 AM
WHIRLPOOL Drive motor - 2 speed, AP2905451 | AppliancePartsPros.com This thread Refback 06-02-2011 11:11 AM
Part Details - WHIRLPOOL Drive motor - 2 speed, part number: AP2905451 This thread Refback 06-01-2011 12:16 PM
WHIRLPOOL Whirlpool direct drive washer pump, AP2907492 | AppliancePartsPros.com This thread Refback 05-30-2011 07:40 PM
Part Details - WHIRLPOOL Whirlpool direct drive washer motor coupling, part number: AP3963893 This thread Refback 05-29-2011 06:54 PM
WHIRLPOOL Neutral drain transmission, AP3096209 | AppliancePartsPros.com This thread Refback 05-28-2011 04:08 PM
Similar Threads
direct drive washer cecil tillery Washer Repair 1 08-17-2009 06:35 PM
replacing drive coupleing on Whirlpool direct drive washer bbuck222 Washer Repair 2 08-06-2009 07:34 AM
Direct drive washer brake yurman Washer Repair 1 08-02-2009 04:35 AM
Replacing direct drive washer brake shoes richappy Forum Announcements 0 02-28-2009 07:38 AM
Direct Drive Washer JNOLES Washer Repair 1 09-19-2007 04:24 PM
