| » Replacing direct drive washer brake shoes |
I'm new here, and I think my machine is to do with the brakes samething, because it makes a bad noise when it spins have mastered everyhting As for the hull of the washing machine is coupling the off.I see cycle.I Great shape, because my motor off...
I have replaced my washer and I would like to repair the old one and give it away. When it went into the spin mode the motor smoked. unplugged and checked motor,OK. Removed the agitator and the spanner nut but I cant get the basket out. I removed the transmission. Looking at the clutch and brake , can someone break it down to me how they work? The spin tube would not come out either. I am a TV tech. that opened my own shop and expanded into appliances, had 10 employees for 35 years, retired in 95 and am now 86. A little handicapped due to age. I love to understand how things work. Can you help??
All info is in the sticky "replacing direct drive washer brake shoes". You can clean the rust off the top of the spin tube to allow it's removal; lay the washer on it's back to prevent oil coming out.In my service work, I never pull out or replace the spin tube, unless it is damaged by a loose drive block.To change brakes, I just pry it down a little. Also, when removing the pump, I never pull the hoses off, just jam it on the frame to the left.
__________________
- Last edited by richappy : 05-07-2011 at 06:08 AM. |
Quote:
2. Is putting oil on the brake shoes necessary? 3. Last, will any silicone grease work on the roller. I mean, I am buying the brake shoes through your website but buying this lubricant: WHIRLPOOL Lubricant, part number: AP3131935 that almost cost as much as the brake itself seems like a waste of money. |
Quote:
You can usually obtain a technician manual of most washers by looking beneath the control panel assembly. For front loaders, it is usually behind the lower toe panel or sometimes on the inner side wall. You can also order most tech manuals from Sears. |
Hello. I pulled my motor from the transmission and tried to rotate the transmission using the coupler. The shaft just keeps turning. It doesn't engage the basket at all.
I replaced the coupler but it broke during the first load. When I first tried to rotate the shaft clockwise,it was really hard to turn. I tried to turn the basket by hand and it moved but it too was hard to turn. After I turned the basket by hand,the shaft doesn't catch on anything. Is this a brake shoes problem? Thanks |
An update to my question:
I pulled the transmission out to look at the brake pads and put a little oil on the pads. They don't seem to be very tight,they turn easily in the housing. Can I rule out the brake pads as the reason for the coupler breaking? |
| Display Modes | |
LinkBack to this Thread: http://forum.appliancepartspros.com/washer-repair/3265-replacing-direct-drive-washer-brake-shoes.html
| Posted By | For | Type | Date | |
| Part Details - WHIRLPOOL Spin Tube Thrust Washer, part number: AP2905330 | This thread | Refback | 09-12-2011 04:50 PM | |
| WHIRLPOOL Neutral Drain Transmission, AP3096209 | AppliancePartsPros.com | This thread | Refback | 09-12-2011 07:20 AM | |
| Part Details - WHIRLPOOL Motor - Drive, part number: AP2907254 | This thread | Refback | 09-12-2011 03:39 AM | |
| WHIRLPOOL Spin Tube Thrust Washer, AP2905330 | AppliancePartsPros.com | This thread | Refback | 09-09-2011 08:27 PM | |
| WHIRLPOOL Motor - Drive, AP2907254 | AppliancePartsPros.com | This thread | Refback | 09-06-2011 10:34 AM | |
| Part Details - WHIRLPOOL Agitator Dogs, part number: AP3119063 | This thread | Refback | 09-05-2011 05:26 PM | |
| Part Details - WHIRLPOOL Gear and Pinon, part number: AP3094405 | This thread | Refback | 09-03-2011 04:42 PM | |
| WHIRLPOOL 285938 Timer, AP3605418 | AppliancePartsPros.com | This thread | Refback | 08-31-2011 05:46 PM | |
| WHIRLPOOL Neutral Drain Transmission, AP3096209 | AppliancePartsPros.com | This thread | Refback | 08-31-2011 09:14 AM | |
| WHIRLPOOL 3360629 Neutral Drain Transmission, AP3096209 | AppliancePartsPros.com | This thread | Refback | 08-31-2011 06:05 AM | |
| WHIRLPOOL Switch - Sen, AP4501024 | AppliancePartsPros.com | This thread | Refback | 08-30-2011 05:02 PM | |
| WHIRLPOOL 285785 Clutch Assembly, AP3094537 | AppliancePartsPros.com | This thread | Refback | 08-29-2011 03:30 PM | |
| Part Details - WHIRLPOOL Clutch Assembly, part number: AP3094537 | This thread | Refback | 08-21-2011 08:09 AM | |
| WHIRLPOOL 285792 Basket Drive and Brake Assembly, AP3094539 | AppliancePartsPros.com | This thread | Refback | 08-21-2011 02:13 AM | |
| WHIRLPOOL 3360629 Neutral Drain Transmission, AP3096209 | AppliancePartsPros.com | This thread | Refback | 08-21-2011 02:05 AM | |
| WHIRLPOOL 389248 Drive Motor - 2 Speed, AP2905451 | AppliancePartsPros.com | This thread | Refback | 08-20-2011 08:09 AM | |
| Part Details - WHIRLPOOL Clutch Assembly, part number: AP3094537 | This thread | Refback | 08-17-2011 04:23 PM | |
| WHIRLPOOL Automatic Washer (direct Drive) - Whirlpool Repair Manuals, AP3073574 | AppliancePartsPros.com | This thread | Refback | 08-14-2011 01:56 PM | |
| WHIRLPOOL Basket Drive and Brake Assembly, AP3094539 | AppliancePartsPros.com | This thread | Refback | 08-14-2011 09:26 AM | |
| WHIRLPOOL Whirlpool Direct Drive Washer Motor Coupling, AP3963893 | AppliancePartsPros.com | This thread | Refback | 08-08-2011 08:00 AM | |
| WHIRLPOOL 285362 Gear & Pinon, AP3094405 | AppliancePartsPros.com | This thread | Refback | 08-06-2011 11:56 PM | |
| WHIRLPOOL 388253 Neutral Drain Kit, AP3018165 | AppliancePartsPros.com | This thread | Refback | 08-05-2011 06:26 PM | |
| WHIRLPOOL 285753A Whirlpool Direct Drive Washer Motor Coupling, AP3963893 | AppliancePartsPros.com | This thread | Refback | 08-01-2011 03:17 PM | |
| WHIRLPOOL 285438 Brake Shoe, AP3094432 | AppliancePartsPros.com | This thread | Refback | 07-18-2011 09:38 AM | |
| WHIRLPOOL Whirlpool Direct Drive Washer Pump, AP2907492 | AppliancePartsPros.com | This thread | Refback | 07-16-2011 03:33 PM | |
| WHIRLPOOL W10292584 Switch - Sen, AP4501024 | AppliancePartsPros.com | This thread | Refback | 07-10-2011 02:20 PM | |
| WHIRLPOOL 285792 Basket Drive and Brake Assembly, AP3094539 | AppliancePartsPros.com | This thread | Refback | 07-07-2011 05:58 PM | |
| Part Details - WHIRLPOOL Agitator Dogs, part number: AP3119063 | This thread | Refback | 07-01-2011 01:31 PM | |
| WHIRLPOOL Agitator Dogs, AP3119063 | AppliancePartsPros.com | This thread | Refback | 06-30-2011 06:38 PM | |
| WHIRLPOOL Automatic Washer (direct Drive) - Whirlpool Repair Manuals, AP3073574 | AppliancePartsPros.com | This thread | Refback | 06-24-2011 03:35 PM | |
| WHIRLPOOL 285938 Timer, AP3605418 | AppliancePartsPros.com | This thread | Refback | 06-23-2011 02:09 PM | |
| WHIRLPOOL Neutral Drain Transmission, AP3096209 | AppliancePartsPros.com | This thread | Refback | 06-23-2011 11:35 AM | |
| Part Details - WHIRLPOOL Gear & Pinon, part number: AP3094405 | This thread | Refback | 06-21-2011 07:53 AM | |
| Part Details - WHIRLPOOL SWITCH-SEN, part number: AP4501024 | This thread | Refback | 06-20-2011 05:43 PM | |
| WHIRLPOOL 285785 Clutch assembly, AP3094537 | AppliancePartsPros.com | This thread | Refback | 06-18-2011 10:33 AM | |
| WHIRLPOOL 3360629 Neutral drain transmission, AP3096209 | AppliancePartsPros.com | This thread | Refback | 06-16-2011 06:08 PM | |
| WHIRLPOOL SWITCH-SEN, AP4501024 | AppliancePartsPros.com | This thread | Refback | 06-15-2011 02:42 PM | |
| WHIRLPOOL Whirlpool direct drive washer motor coupling, AP3963893 | AppliancePartsPros.com | This thread | Refback | 06-15-2011 05:29 AM | |
| WHIRLPOOL Whirlpool direct drive washer pump, AP2907492 | AppliancePartsPros.com | This thread | Refback | 06-09-2011 01:29 AM | |
| Part Details - WHIRLPOOL Basket drive and brake assembly, part number: AP3094539 | This thread | Refback | 06-06-2011 09:39 PM | |
| Part Details - WHIRLPOOL Whirlpool direct drive washer motor coupling, part number: AP3963893 | This thread | Refback | 06-05-2011 02:07 PM | |
| WHIRLPOOL Drive motor - 2 speed, AP2905451 | AppliancePartsPros.com | This thread | Refback | 06-04-2011 06:00 PM | |
| Part Details - WHIRLPOOL Brake shoe, part number: AP3094432 | This thread | Refback | 06-04-2011 09:04 AM | |
| Part Details - WHIRLPOOL Brake shoe, part number: AP3094432 | This thread | Refback | 06-03-2011 09:38 PM | |
| WHIRLPOOL Brake shoe, AP3094432 | AppliancePartsPros.com | This thread | Refback | 06-03-2011 05:46 AM | |
| WHIRLPOOL Drive motor - 2 speed, AP2905451 | AppliancePartsPros.com | This thread | Refback | 06-02-2011 11:11 AM | |
| Part Details - WHIRLPOOL Drive motor - 2 speed, part number: AP2905451 | This thread | Refback | 06-01-2011 12:16 PM | |
| WHIRLPOOL Whirlpool direct drive washer pump, AP2907492 | AppliancePartsPros.com | This thread | Refback | 05-30-2011 07:40 PM | |
| Part Details - WHIRLPOOL Whirlpool direct drive washer motor coupling, part number: AP3963893 | This thread | Refback | 05-29-2011 06:54 PM | |
| WHIRLPOOL Neutral drain transmission, AP3096209 | AppliancePartsPros.com | This thread | Refback | 05-28-2011 04:08 PM | |
| direct drive washer | cecil tillery | Washer Repair | 1 | 08-17-2009 06:35 PM |
| replacing drive coupleing on Whirlpool direct drive washer | bbuck222 | Washer Repair | 2 | 08-06-2009 07:34 AM |
| Direct drive washer brake | yurman | Washer Repair | 1 | 08-02-2009 04:35 AM |
| Replacing direct drive washer brake shoes | richappy | Forum Announcements | 0 | 02-28-2009 07:38 AM |
| Direct Drive Washer | JNOLES | Washer Repair | 1 | 09-19-2007 04:24 PM |
