Spin cycle seems to be not working, do you think i need a new clutch assembly
If you have not already done so, I would first by-pass the lid switch and determine if that is the problem.
If that is not the problem, please post, and give us some more detail on your problem, like, has the spin been slowing down, does the machine drain ok, does the agitate cycle work ok, does it make any noise when it goes into the spin cycle, etc?
Good luck and let us know how it turns out.
