bgmike8
#1 Posted : Tuesday, May 5, 2009 1:00:22 PM(UTC)
bgmike8
when it is time to agitate, washer humms then nothing then humms then nothing then humms again and usually quits leaving the washer full of water and a slight burning smell
Drags1998
#2 Posted : Tuesday, May 5, 2009 3:57:57 PM(UTC)
Drags1998
It sounds like the motor is bad!!! or if you were REALLY LUCKY something is stuck in the water pump:)
bgmike8
#3 Posted : Tuesday, May 5, 2009 5:50:52 PM(UTC)
bgmike8
doesnt the motor contro; the spinning too? is it hard to replace the motor?
Drags1998
#4 Posted : Wednesday, May 6, 2009 12:12:06 PM(UTC)
Drags1998
Yes to the spinning, the motor runs 1 way to wash, The other way to spin.:)
bgmike8
#5 Posted : Wednesday, May 6, 2009 7:33:48 PM(UTC)
bgmike8
okay. so definetly need a new motor. should i order one and replace it myself or just buy a new washer?
just to be clear. my washer works fine except when it comes time to agitate. then it does the humming and stops where it is at. if i move the timer to spin then it drains and spins thank you for your time and knowlege.:)
Drags1998
#6 Posted : Thursday, May 7, 2009 11:28:05 AM(UTC)
Drags1998
Without testing the motor, I'm not sure!!!! If it drains and spins correctly, It could also be the timer.:(
bgmike8
#7 Posted : Thursday, May 7, 2009 9:40:19 PM(UTC)
bgmike8
it does it on all modes. how to i test the motor?
