| » no cold water |
Model Number: mvwc400vw1 Brand: Maytag Age: 1 - 5 years
My washer has no cold water. I switched the hoses so now I can get the cold water on the hot setting. My question is I can see the valve from the inside but what do I need to do to access it to replace it.
What you really have is a direct drive Whirlpool. If you will look at the video library at the top of this page you will find a video on how to open it up and check it out. Before replacing the valve assembly use a multi-meter to see that the cold water valve is getting power when it calls for it.
__________________
Quote:
__________________
| Display Modes | |
| Cold/Cold, Warm/Cold and Hot/Cold Button Settings do not trigger the Rinse cycles | ralphdisimone@gmail.com | Washer Repair | 1 | 10-12-2010 02:55 PM |
| no cold water on cold/cold cycle | rpbmd | Washer Repair | 1 | 08-28-2009 10:04 AM |
| washer won"t run on cold cold water setting | jwh4969 | Washer Repair | 1 | 12-23-2008 06:41 AM |
| Whirlpool LA5300XM Cold water trickles, warm water flows properly | ajaysheetal | Washer Repair | 2 | 02-14-2008 04:49 PM |
| no cold water alone coming in .do get hot or warm. so cold must be comin through valv | misterfixall | Washer Repair | 1 | 11-16-2007 12:51 PM |
