Discuss
whirlpool washer will not drain or spin
 in
Washer Repair
Washer agitates fine, but then does not go on to the next step of rinse. There is then no sound
Appliance Repair Forum > Appliance Repair Help > Washer Repair » whirlpool washer will not drain or spin
  #1 (permalink)
Old 05-04-2009, 09:47 AM
Junior Member
llbishop7@cs.com is on a distinguished road
Question whirlpool washer will not drain or spin
Model Number: lsc6244awo   Brand: Whirlpool   Age: More than 10 years
Washer agitates fine, but then does not go on to the next step of rinse. There is then no sound of anything happening. It is as if the washer is simply not turned on or plugged in. This is the case regardless of which cycle I am in. Every cycle agitates but does nothing else after the agitation is complete.It does not drain, rinse, or spin.
Related Models
Whirlpool LSC6244BQ0 Washers*
Whirlpool LSC6244BW0 Washers*
Whirlpool LSC8244BG0 AUTOMATIC WASHER
Whirlpool LSC8244BG1 AUTOMATIC WASHER
Whirlpool LSC8244BN0 AUTOMATIC WASHER
Whirlpool LSC8244BN1 AUTOMATIC WASHER
Whirlpool LSC8244BQ0 AUTOMATIC WASHER
Whirlpool LSC8244BQ1 AUTOMATIC WASHER
Whirlpool LSC8244BW0 AUTOMATIC WASHER
Whirlpool LSC8244BW1 AUTOMATIC WASHER
Whirlpool LSC8244BZ0 AUTOMATIC WASHER
Whirlpool LSC8244BZ1 AUTOMATIC WASHER
Whirlpool LSC8244DQ0 AUTOMATIC WASHER
Whirlpool LSC8244DZ0 AUTOMATIC WASHER
Whirlpool LSC8244EQ0 WASHER
Whirlpool LSC8244EQ1 WASHER
Whirlpool LSC8244EZ0 WASHER
Whirlpool LSC8244EZ1 WASHER
Whirlpool LSC8245AN0 AUTOMATIC WASHER
Whirlpool LSC8245AQ0 AUTOMATIC WASHER
Whirlpool LSC8245AW0 Washers*
Whirlpool LSC8245BW0 Washers*
Whirlpool LSC9000PW0 AUTOMATIC WASHER
Whirlpool LSC9000PW1 AUTOMATIC WASHER
Whirlpool LSC9000PW2 AUTOMATIC WASHER
Whirlpool LSC9245BN0 AUTOMATIC WASHER
Whirlpool LSC9245BN1 AUTOMATIC WASHER
Whirlpool LSC9245BQ0 AUTOMATIC WASHER
Whirlpool LSC9245BQ1 AUTOMATIC WASHER
Whirlpool LSC9245BW0 AUTOMATIC WASHER
Whirlpool LSC9245BW1 AUTOMATIC WASHER
Whirlpool LSC9245BZ0 AUTOMATIC WASHER
Whirlpool LSC9245BZ1 AUTOMATIC WASHER
Whirlpool LSC9355AG0 AUTOMATIC WASHER
Whirlpool LSC9355AN0 AUTOMATIC WASHER
Whirlpool LSC9355AW0 Washers*
Whirlpool LSC9355BN0 AUTOMATIC WASHER
Whirlpool LSC9355BN1 AUTOMATIC WASHER
Whirlpool LSC9355BQ0 AUTOMATIC WASHER
Whirlpool LSC9355BQ1 AUTOMATIC WASHER
Whirlpool LSC9355BW0 AUTOMATIC WASHER
Whirlpool LSC9355BW1 AUTOMATIC WASHER
Whirlpool LSC9355BZ0 AUTOMATIC WASHER
Whirlpool LSC9355BZ1 AUTOMATIC WASHER
Whirlpool LSC9355DQ0 AUTOMATIC WASHER
Whirlpool LSC9355DZ0 AUTOMATIC WASHER
Whirlpool LSC9355EQ0 AUTOMATIC WASHER
Whirlpool LSC9355EQ1 DIRECT-DRIVE WASHER
Whirlpool LSC9355EZ0 AUTOMATIC WASHER
Whirlpool LSC9355EZ1 DIRECT-DRIVE WASHER
Admiral LSD2615HEB REF - SXS/I&W
Admiral LSD2615HEW REF - SXS/I&W
Admiral LSD2615HEZ REF - SXS/I&W
Maytag LSE1000 STACKED LAUNDRY- ELE
Maytag LSE1000T Stacked Laundry - Ele
Jenn-Air LSE2700W STACKED LAUNDRY- ELE
Jenn-Air LSE2700W-8 STACKED LAUNDRY- ELE
Jenn-Air LSE2700W-C STACKED LAUNDRY- ELE
Jenn-Air LSE2704W STACKED LAUNDRY- ELE
Jenn-Air LSE2704W-8 STACKED LAUNDRY- ELE
Maytag LSE7800 STACKED LAUNDRY- ELE
Maytag LSE7800ACE STACKED LAUNDRY- ELE
Maytag LSE7800ACL STACKED LAUNDRY- ELE
Maytag LSE7800ACW STACKED LAUNDRY- ELE
Maytag LSE7800ADE STACKED LAUNDRY- ELE
Maytag LSE7800ADL STACKED LAUNDRY- ELE
Maytag LSE7800ADW STACKED LAUNDRY- ELE
Maytag LSE7800AEE STACKED LAUNDRY- ELE
Maytag LSE7800AEL STACKED LAUNDRY- ELE
Maytag LSE7800AEW STACKED LAUNDRY- ELE
Admiral LSE7800AGE STACKED LAUNDRY- ELE
Admiral LSE7800AGL STACKED LAUNDRY- ELE
Maytag LSE7804ACE STACKED LAUNDRY- ELE
Maytag LSE7804ACL STACKED LAUNDRY- ELE
Maytag LSE7804ACM STACKED LAUNDRY- ELE
Maytag LSE7804ADE STACKED LAUNDRY- ELE
Maytag LSE7804ADL STACKED LAUNDRY- ELE
Maytag LSE7804ADM STACKED LAUNDRY- ELE
Maytag LSE7804AEE STACKED LAUNDRY- ELE
Admiral LSE7804AGE STACKED LAUNDRY- ELE
Admiral LSE7804AGL STACKED LAUNDRY- ELE
Admiral LSE7804AGM STACKED LAUNDRY- ELE
Maytag LSE7806ACE STACKED LAUNDRY- ELE
Maytag LSE7806ACM STACKED LAUNDRY- ELE
Maytag LSE7806ACQ STACKED LAUNDRY- ELE
Maytag LSE7806ADE STACKED LAUNDRY- ELE
Maytag LSE7806ADM STACKED LAUNDRY- ELE
Maytag LSE7806ADQ STACKED LAUNDRY- ELE
Maytag LSE7806AEE STACKED LAUNDRY- ELE
Maytag LSE7806BCE STACKED LAUNDRY- ELE
Admiral LSE7806GGE STACKED LAUNDRY- ELE
Whirlpool LSE9355BQ0
Whirlpool LSE9355BZ0
Maytag LSE9900 STACKED LAUNDRY- ELE
Maytag LSE9900ACE STACKED LAUNDRY- ELE
Maytag LSE9900ACL STACKED LAUNDRY- ELE
Maytag LSE9900ACW STACKED LAUNDRY- ELE
Maytag LSE9900ADE STACKED LAUNDRY- ELE
Maytag LSE9900ADL STACKED LAUNDRY- ELE
Maytag LSE9900ADW STACKED LAUNDRY- ELE
Maytag LSE9900AEE STACKED LAUNDRY- ELE
Maytag LSE9900AEL STACKED LAUNDRY- ELE
Maytag LSE9900AEW STACKED LAUNDRY- ELE
Maytag LSE9900AFL STACKED LAUNDRY- ELE
Maytag LSE9900AFW STACKED LAUNDRY- ELE
Maytag LSE9904ACE STACKED LAUNDRY- ELE
Maytag LSE9904ACL STACKED LAUNDRY- ELE
Maytag LSE9904ACM STACKED LAUNDRY- ELE
Maytag LSE9904ADE STACKED LAUNDRY- ELE
Maytag LSE9904ADL STACKED LAUNDRY- ELE
Maytag LSG1000 STACKED LAUNDRY- GAS
Maytag LSG1000T Stacked Laundry - Gas
Jenn-Air LSG2700W STACKED LAUNDRY- GAS
Jenn-Air LSG2704W STACKED LAUNDRY- GAS
Maytag LSG7800 STACKED LAUNDRY- GAS
Maytag LSG7800AAE STACKED LAUNDRY- GAS
Maytag LSG7800AAL STACKED LAUNDRY- GAS
Maytag LSG7800AAW STACKED LAUNDRY- GAS
Maytag LSG7800ABE STACKED LAUNDRY- GAS
Maytag LSG7800ABL STACKED LAUNDRY- GAS
  #2 (permalink)
Old 05-04-2009, 10:16 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Well, that's not good.
You need to check your lid switch. To do this, unplug the machine andtake out the two screws that hold the console to the cabinet, and flip the console back. This will expose a wire set coming from the console and going to the cabinet, with a plastic connection. Undo the connection, and use a solid insulated wire to bypass the lid switch by twisting the wire into a u shape and inserting the exposed ends into the end holes on the plastic connector coming from the console.
Plug in the machine and move the timer to the spin position, and engage it. If the machine spins your lid switch is bad and needs to be replaced.
See any of the hundreds of posts on replacing the lid switch if you need further info.
Good luck and let us know what you find.
__________________
  #3 (permalink)
Old 08-16-2012, 08:09 PM
Junior Member
dfghjk is on a distinguished road
Default will leaving the connector jumped damage the machine?
Hi, thanks so much, using your advice above I was able to get my machine draining and spinning again. It's probably a 25 year old machine so I hesitate to even spend the money to replace the switch. As long as there are no kids in the house and I accept the risk of having the machine always thinking the door is closed (and therefore being able to spin if the door is opened) ... will it damage the machine further to just leave the connector jumped? I have it jumped now and wrapped with electrical tape, and the machine is working beautifully.
  #4 (permalink)
Old 08-17-2012, 03:24 PM
Senior Expert
APP Volunteer
Default
it will not harm the machine to leave the lid switch permanently by-passed, but it is a safety device and I urge you to replace the switch. If you do not I would put a very visible notice on the machine that the lid switch is not working and to bed very careful opening the lid.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer won't drain or spin KellaC32 Washer Repair 3 12-02-2009 10:37 AM
whirlpool duet washer will not drain and spin bcanebres Washer Repair 0 11-25-2009 07:57 AM
whirlpool washer wont spin but will drain charlissa Washer Repair 1 10-21-2009 04:03 AM
Whirlpool washer won't spin or drain Jon B Washer Repair 1 10-09-2009 09:27 AM
Whirlpool washer will not drain or spin. Is it the lid switch? conramana Washer Repair 2 06-11-2009 08:55 PM
